| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
Hey guys, don't think I've ever posted my build on these forums so I wanted to share!
This thing is killing my wallet. Here's the modlist so far in no particular order. Greddy titanium valve springs crower titanium valve set crower 272 cam phase 2 motorsports rocker arm stoppers acid treated head multi angle valve job ported and polished ports ARP head bolts and studs HKS 1.04mm multilayer metal head gasket brian crower bronze valve guides 5 Ziegen Oil cap Nismo rod bearings NIsmo main bearings Nismo thrust bearings Eagle h-beam rods OEM pistons (new) OEM rings (new) OEM oil pan (new. Got replaced because other one was dented) Greddy blow-by canister ARP rod bolts Greddy aluminum pulleys Aeromotive tsunami fuel pump aeromotive 100 micron inline fuel filter aeromotive fuel pressure regulator aeromitve fuel pressure gauge greddy fuel pressure fittings BGRG custom high pressure fuel lines with 6AN fittings Apexi SAFC 2 fuel controller Z32 Mass air flow sensor Samco braided radiator hoses greddy radiator cap koyo polished aluminum radiator 12" electric fan Phase 2 motorsports aluminum coolant tank B-road carbon fiber air diversion plate AEM air filter Greddy oil filter (haha) Precision 5831 Turbo DOC race t4 top mount turbo manifold Tial wastegate ISIS turbo lines Greddy turbo timer steel braided oil return line JDM lab aluminum intercooler JDM lab intercooler piping Blitz BOV Apexi Downpipe Apexi dual N1 Exhaust system Z32TT dual piston front calipers Z32TT brembo rotors (front) 240sx drilled rotors (rear) phase 2 motorpsorts steel braided brake lines tokiko performance shocks tein s performance springs FR and RR began racing strut tower braces short shifter corbeau seats prosport boost, oil temp, & oil pressure gauges driveshaftshop 1pc steel driveshaft kaaz 2-way differential 18 in staggered sportmax xxr wheels mishimoto starter body kit battery relocated to the trunk I'm not driving the car right now it needs injectors, wideband sensors, proper boost controller, AEM engine management, and then she'll be ready to play. That's gonna come in the fall though along with full intake manifold side rebuild. So here's pics from the latest mods and I'll follow them with pictures of the entire build from the start. I'll try to keep them in order but honestly that's going to be hard to do haha. :inout: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now on to the older pics that aren't in any particular order and s*** dude I've lost a lot of the pictures. These are in no particular order and show older turbo setups, along with some of the mods being put in. I've lost so many pics this is not going to be all of them but enough to get the jist of it. ![]() |
