#751 |
#752 |
![]() Join Date: Dec 2002
thanks for the reply.
I know hitler used ramjets on his v2 rockets in ww2. They said that even though they were not accurate, just the sound would scare people out of the cities. Can you tell me this. How fuel efficient is this engine? Can you make enough thrust (besides solid fuel) to lift a plane, its engine, and fuel?
#753 |
actually, what was in the v1s were valved pulsejets. they were nicknamed buzzbombs because they make this very annoying sound when running. the v2s were just liquid fueled rockets. here is a youtube video of an rc plane runnin 2 suck pulsejets to give you an idea of the proper sound. [ame]http://www.youtube.com/watch?v=1e-Ar7gb4tQ[/ame]
and yes, if made to the proper size, it will prouce enough thrust to get itself, its fuel, and a plane off the ground. as for efficiency, mine is far from it. if i spent a whole lot of time crunching numbers in some very complex equations, i could find the proper formulas to fine tune my pulsejet and make it more powerful and more efficient. as for pulsejets in general, they are kinda like rotary engines. Not the most efficient, they can make a good amount of power under te right conditions, and someone had to be thinkin WAY outside te box to come up with them. remember the show junkyard wars? check this out... [ame]http://www.youtube.com/watch?v=ZxrLwDz9cCM[/ame] and for anyone wanting to experiment with pulsejets, here is an easy way to try it out... [ame]http://www.youtube.com/watch?v=AePLpM5SnqE&feature=related[/ame] |
#754 |
Damn Bill (driftstyre) those front lateral and tension arms you built are SICK! Nice work!
Here is the louver shroud unit installed in the hood i fabbed for our kits. This and the hood pins come with the vmount kit. Going to test it a bit and add some more louvers in the middle if need be like we did on the RX7 FC kit but im learning here making sure air is being sucked out. ![]() ![]() ![]() ![]()
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803 -->Neukin Store<-- -->DRIFT Clutch Store<-- |
#755 |
![]() Join Date: Jan 2007
Clowny awesome post man deff not a good idea to post right b4 4th of july lol beer fireworks and now pulse jet nice lol Ill post some video.
V mount is dope If i could fit a large enough core i would be really interested but the rear mounted radiator is already in the works....Thanks to Bill i have been reading about NACA ducts for the past 2 days. Plan: Naca ducts dual one right next to the other, And beacuase i still like to be pretty and functional a little carbon duct over them. "NACA ducts kinda go the wrong way for the shape of the rear qtr windows...Plus side is that ill be making 2 sets one for my S14 and one set for Bills Incredible S13. Have a good holiday guys and be safe. |
#756 |
The Garrett core is support to be one of the most efficient out there. That unit there supports about 700hp or is said to keep temps cooler in that range max. I like the Apexi core but cost is a issue, would like to test that against a Garrett. The larger your intercooler the more lag or responsiveness so this was prime in our opinion. What size core do you plan to run?
#757 |
In all honesty I think i was not focused when i made my prior post... "DRUGS DUE TO BROKEN FOOT" Anyway in all honesty I guess i could do a V mount its just i would need a really nice setup duct wise to get the air in and out.
Your kits look bad ass though nice work man. |
#758 |
Sorry guys been really buisy. I have the following to post up in the next few days.
Sound deadening removal step by step. Chassis seam welding step by step. Gangster ass roll cage building step by step. Our new car build step by step RHD TURBO LS1 FD Oh yea. and a complete Rb25det s13 build, and a e36 euro itb powered e30 m3 cage build. Who wants to see it?
#761 |
![]() Join Date: Jan 2005
yeah bring on the write ups
especially the seam welding one so i can seam weld my chassis it wants me to
Need automotive work done in the antelope valley? Ask me how i can help. |
#768 |
![]() Join Date: Dec 2006
you've got a lot of balls to do that to a newer car. I dont mind cutting up old cars...but if its been made within the past few years...its hard for me to do it. lol
#769 | |
![]() Join Date: Sep 2004
Wayne |
#770 | ||
![]() Join Date: May 2004
I will post pics of the shield I made for it later. |
#771 |
![]() Join Date: Oct 2006
i thought i'd try to make a vmount.
it took me about a week, never welded aluminum before! lol i cut about two inches out of my front mount's core and used that. its still got a few kinks that i need to work out. i'll be re-routing the water lines to the top side of the radiator. as well as re-route the upper water lines. i put a filler neck on the upper water neck coming off the head, but ill probably put a bubbler tank in there also also, im using .032 T6061 sheet aluminum for the ducting. i need a rivet gun lolz im building a uras look-a-like hood vent too
The gap between MORE and ENOUGH never closes. DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.Secret Society |
#775 | |
do you have any pictures of your v-mount set up without your aero on the s14 luis. I would be curious to see the layout, I don't want to go through the trouble of replacing the radiator support and bash bar on this car if I am going to have to remove most of that stuff anyway.
Wayne |
#776 | |
#777 | |
(here is an example of doing a roof skin swap on a s14) http://www.northwestnissans.com/boar...ad.php?t=78303
Wayne |
#778 |
Philosopher King
It is electric so you can mount it any where you want and free up space for more accessories or just more clearance.
G O L D E N B E A R R E P U B L I C |
