![]() Join Date: Sep 2011
Trader Rating: (35)
![]() Feedback Score: 35 reviews
Ka24de part outs
1x s14 complete Ka24de
140k miles, oil pump failure, rod knock 1x s13 complete Ka24de Fresh head, and headgasket, shims or some sort of light tapping between 3k rpm to 6k rpm. Pulled each injector to check if it's bottom end..it seems it's NOT. S13 ka24de parts S13 head (decked and cleaned) $150 S13 bottom end (ticking noise) $100 S13 power steering pump with bracket $70 S13 oil pan $20 S13 intake manifold no injectors $50 S13 injectors in rail $50 S13 flywheel $40 S13 used clutch $20 S13 5speed Trans $200 S13 drive shaft $80 S13 valve cover $30 S13 240sx engine harness $75 S13 240sx ecu manual $45 S14 ka24de parts S14 power steering pump and bracket $75 S14 alternator $40 S14 fuel rail $50 S14 intake $60 (great mod for S13 guys) S14 starter $40 S14 valve cover $30 S14 distributor $40 S14 bottom end (knock) $100 S14 oil pan $20 S14 head $100 S14 flywheel $40 S14 clutch $40 looks near new! S14 Trans $sold S14 distributor $50 with wires 1992 Nissan 240sx Fastback I also have a s13 fastback nearly parted but still has some parts Sold parts.. Front end, driver door, dash, front seats, carpet, struts, rear tail lights, gas tank,cluster, cluster trim, everything else should be there.. 1994 Nissan 240sx VERT ...just to list a few..pm me! S13 cluster dohc $60 S13 rear gas door cable $40 S13 wind shield $50 S13 vert doors $20each S13 power regulators $30each S13 door panels, black S13 stuff under dash (name your part) S13 front sunframe S13 front knuckles $50 S13 rear subframe $40 S13 welded diff $140 And...a vert..nearly parted but still has some parts as well. Sold parts... Front end, dash, carpet, door panels, nearly all interior, rear bumper, 2x ka24 Trans s13 1x Ka24 Trans s14 SOLD Whole s13 5speed swap $500 -drive shafts -5speed transmission -clutch bolts and clutch -flywheel bolts and flywheel -sandwich plate -Bell housing bolts -speed sensor -shifter -Trans mount MT -clutch pedal -master scylinder -clutch cylinder - clutch hardline -clutch soft hose Pm me for parts! From the looks of it..I'll probably have them. Lol Says upload failed everytime in try to add pics. Just pm me for pics I guess. Sent from my SAMSUNG-SM-G870A using Tapatalk ![]() ![]() ![]() Last edited by CoupedupRB; 08-17-2018 at 12:47 PM.. |
