--New Product-- Laser Engraved VIN Number Plates
Have you replaced your old cracked dash for a new one and now your VIN numbers don't match?? I can laser engrave you a new VIN number plate on a number of different color anodized aluminum plates. $9.00 for each plate with FREE Shipping! Pm me on here or shoot me an email at [email protected]
These are made out of Aluminum and cut to size and then engraved. They can be drilled and riveted, super glued or Jb Welded on. No stickers here! Thanks! Jon
#6 | |
Could you use this in the wrong way? I don't really think so.. If you are driving around with a different dash with the wrong VIN wouldn't that be more of a problem? The VIN on the motor on everyone's swaps would also be wrong. This is just a way to correct that and get the same VIN on all of your parts to be legit. Plus if someone did steal your car and later on you find your parts they would have matching VINs to your car and registration.
The main VIN I read on a car stop is the dash VIN. I use this to confirm that the VIN number matches the registered Vin on the License plate. I could see this plate being used for illegal agendas. I am in no way shape or form telling you that you are breaking the law or are wrong in producing these. I'm just letting you know that this could be an issue. Although, using these VIN plates I could register an R-34 as a Maxima, Lol.
(My Experience in Law Enforcement comes from 6 years and counting in patrol in the largest metropolitan department in Pennsylvania.) Last edited by Kenzo; 05-24-2012 at 12:35 PM.. Reason: Grammer, beers |
![]() Join Date: Feb 2008
![]() Feedback Score: 29 reviews
Could just as easily get one from a junkyard Maxima too. Just for sake of argument. The firewall should still have the chassis vin on the plate as well as embossed into the metal.
#10 | |
Also, for the TC, check local statutes for the Vehicle code and state legislation, this excerpt is from the us crimes code. "18 USCS § 2321 (2003) § 2321. Trafficking in certain motor vehicles or motor vehicle parts (a) Whoever buys, receives, possesses, or obtains control of, with intent to sell or otherwise dispose of, a motor vehicle or motor vehicle part, knowing that an identification number for such motor vehicle or part has been removed, obliterated, tampered with, or altered, shall be fined under this title or imprisoned not more than ten years, or both." Last edited by Kenzo; 05-24-2012 at 06:52 PM.. Reason: additional content |
#12 | |
So you would be upset if someone had the correct VIN plate that matched their license plate and registration then tear their car apart for it? That makes no sense... The whole point of these is so that everything does match? Some people buy cars with dashes already swapped and want to make their VIN # match. If they didn't match or if the VIN clearly calls out a different car I would understand the need to tear it apart and investigate. But other than that why would you care? The only illegal things I can think of would be to take this VIN and put it on a car and try to sell it using the wrong VIN. Or the biggest illegal way would be to make multiple VINs of the same VIN number and use them on say your track car and your daily driver. If they are both say s13s how would you know which car is which? Anything can be used in an illegal way or the correct way. My intentions of this were to help people who want to make their cars legit.
#13 | |
I would buy a new dash and then put the correct VIN on it. Is that wrong?
Holy shnikeys.....
Yeah...let's tear a car apart....not compare that VIN to what's in the computer and what's stamped on the firewall..... Oi. Keep making awesome stuff! |
![]() Join Date: May 2011
![]() Feedback Score: 15 reviews
The oem vin plates have special rivets on it. If you have different ones or the chp suspect your vin plate is fake then you can get in trouble. I would just run your dash without a vin because i know when older cars are restored they just leave the vin plate off.
The issue of having a dash with a different vin is that chp would just assume that you stole it from a different car. And if the car was filed stolen then you're in trouble.
#17 |
Jonevo, I would tear a car apart if the vin plate looked etched and not factory stamped if the car had no other vin numbers available to compare to the registration. I like the products you make, my point of bringing up legality is due to personal liability if someone uses your product in an illicit manner. Also I wasn't getting smartass with you, I was originally responding to the cat who called me an idiot.
![]() Join Date: Aug 2009
I like the product, but not a good idea to sell these.
Check Out My S13 Build |
#19 |
![]() Join Date: Nov 2007
As far as I understand, it is the purchaser's responsibility to check for legality in their area, and if determined to be illegal, they run the risk of punitive measures as deemed fit by the local authorities. This is very similar to test pipes and many other parts labeled "For off-road use only."
OP: I like your product, and the fact that you are bringing new products to the market. I think it is a good idea to sell these. If people continue to complain in this manner, I recommend you state in the first post that they are for off-road use.
#20 |
By California law you cannot re-attach your own VIN plate with non factory rivets. The legal process is to take your car to a CHP Office for inspection by a VIN officer who will do a complete inspection of your car and then if all is well, will attach a Blue Tag to the door post of the car. That blue tag then becomes the "Official" VIN for the car.
Did it this way when i swapped the dash on my integra
