Parasitic drain?
Hey guys I've been having a battery drain since I got my car it's a 1998 s14. Tested all my fuses in the kick panel with a multimeter and found two 10A fuses reading high. One being the room lamp fuse and the other is the tail lamp fuse. I pulled both fuses out and it seems that the battery draw has stabilized but how do I find the actual problem and fix it? Do I just rip apart the interior and inspect all the wiring? Any help would be appreciated thank you!
