NRG stainless radiator cooling panel for 1995-96 Zenki S14- $75 FIRM
BNIB never installed.. only set on the car for picture. Still has white plastic protectant, never removed. S14 Lowering springs with good shocks (KYB in the rear, unknown in the front) ~10k miles. I upgraded to coils.. heres a pic of them on my car. -$140 Stock S14 Zenki amber side markers- $20 Ka24de Nismo Thermostat- $30 Basically brand new..I had it installed for a couple weeks, but decided to run no thermostat. Tested and works perfectly. SOLDSOLDSOLD!! S14 front & rear mudflaps- good condition $50 p/u or $65 shipped (firm) ALL FOUR SOLDSOLDSOLD!! 14" AN-8 Steel braided line (Great oil drain line for a turbo) Brand new never used or installed..custom made with aluminum ends. -$30 Ka24de top mount cast iron manifold new style flanged for a t3 OR t4 turbo-$90 NEVER used and NEVER installed. 38mm external wastegate flange. This style sits the turbo further away from the bmc for better clearance..which is a hugee pain in the ass if you use a normal manifold. NO heat shields, NO sock covers and NO boiling your brake fluid with this one ![]() Good clearance Pearl White Silvia grille-perfect condition $100 firm -SOLD SOLD SOLD! S14 window washer reservoir- $10 PUMP NOT INCL SOLDSOLDSOLD! New Oil cap- $8 Turbo intake pipe with welded 5/8 bung (for valve cover breather) and 19mm-3/4 bung for recirc of bov- $30 2.5" V-band clamp with ss flanges -$25 only used the clamp for almost a week in attempt to seal an exhaust leak..had to rebuild dump pipe instead. V-band flanges haven't been touched. Still in perfect condition. Stock s14 front sway- $10 S14 clutch line- $10 works perfect.. just replaced with steel braided. Four Bronze 8-spoke DLX Hype 4x114.3 18x7.5- includes ONE good Falken tire -$400 *Also have various stock suspension arms- $20 per set Thanks for looking! ![]() Please pm for quick response or txt 909 720 2419
Friends don't let friends build SR20's. Have faith in your KA!! Last edited by dRift_g0ddess; 11-28-2010 at 10:18 PM.. Reason: added part |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Who makes those wheels??? they look sharp!!! GLWS...
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87 |
stock USDM headlights..made of plastic instead of glass.
brand new glass headlights are $250 a piece.
Friends don't let friends build SR20's. Have faith in your KA!! |
i thought you just wanted one? or do you want both?
Still available..atm.
![]() Join Date: May 2009
Trader Rating: (31)
![]() Feedback Score: 31 reviews
ill take the intake pipe
pm me when your free to pick up
VISIT OUR NEW SITE! streetfaction.net |
#17 |
im tempted for that nimso thermostat and winkers.. ill trade u a formula 1 front strut bar (s14)with sum cash on top?? pm me if interested
-N/A MIATA DAILY DRIVER -93 Z32TT GT2530'S WEEKEND TRACK BEAST |
#18 | |
#25 |
lol nah.. look for a godspeed one, they're pretty cheap and work the same. they only make one for ka but you can mount it to the intake mani with what they give you.
#28 |
460
2 bump limit. You can start new thread in 3 days.
