![]() Join Date: Jun 2008
Hey guys-
Just wrapped up a turbo upgrade and have a lot of leftover OEM RB25 stuff that I took off. Obviously, everything for sale is known good and in excellent condition unless otherwise noted. Here's what I have: RB25DET Stock Turbo - SOLD! In immaculate condition, removed from a running motor that had less than 30K on it, never saw more than stock boost. The pictures really speak for themselves, this thing is CLEAN. ![]() ![]() ![]() RB25DET -6AN Coolant Feed & Return Banjo Fittings for OEM turbo - SOLD! Brand new, never used. Use these to run -6AN stainless braided coolant feed and return lines on your OEM turbo. Includes copper washers, and I have extra ones as well if you need them. ![]() RB25DET Series II ECU - SOLD! Marked with "G8" and P/N 23710-13U01. From a 5 speed R33 GTS-T. ![]() ![]() RB25DET Series II E60 MAF - SOLD! ![]() ![]() RB25DET Turbo Inlet Pipe with recirculation and breather lines - SOLD! ![]() RB25DET OEM Crossover Pipe - $25 Includes OEM coupler that attaches it to the throttle body ![]() ![]() RB25DET OEM Turbo Recirculation Valve - $25 ![]() RB25DET OEM Fuel Rail with 370cc Injectors - SOLD! ![]() RB25DET OEM Fuel Pressure Regulator - $25 each Have two, both in excellent working order. ![]() RB25DET Series II OEM Injector Connectors - SOLD! Someone might be looking for these, I dunno. Swapped them out for Denso plugs when I upgraded to bigger injectors. ![]() RB25DET OEM Oil Cooler / Filter Block - SOLD! Great condition, removed to install an aftermarket cooler. ![]() ![]() 1/8" BSPT to 1/8" NPT Oil Pressure Sensor Adapter - $12 shipped (via regular mail) You need this to run your factory 1/8" BSPT oil pressure sensor in any standard 1/8" NPT aftermarket oil filter relocation or oil cooler block adapter. Useful if you want your 'idiot light' to remain functional as a backup to your aftermarket pressure gauge, or if you are not running an aftermarket gauge at all. This was hard to find. ![]() RB25DET OEM Exhaust Cam Gear - $25 ![]() RB25DET/RB20DET OEM Flywheel Bolts x6 - $20 Excellent condition, I upgraded to an R32 RB26DETT flywheel which uses a different length bolt. ![]() RB25DET Cometic Intake Collector Gasket - $15 Brand new never used. Made out of 0.60" thick Cometic "AFM" material, recommended when running more than stock boost. For OEM crossover style manifold. ![]() RB25DET/RB20DET OEM turbo compressor elbow gasket 3-bolt (new) - SOLD! RB25DET/RB20DET OEM turbo outlet gasket 6-bolt (new) - SOLD! RB25DET/RB20DET OEM turbo outlet gasket 6-bolt (used 200 mi) - SOLD! Took off the used outlet gasket after using it only a couple hundred miles, because I installed a new V-band turbo. Only has slight discoloration, it is the one pictured on the right. Don't have a picture of the new one, it is still in the packaging though. FRSport wants $30+tax and shipping for a new one! :| ![]() RB25DET OEM turbo lock washers - SOLD! Brand new still in the packaging. ![]() RB25DET OEM misc turbo oil/coolant line stuff - $5 for any piece Just some random turbo lines/stuff that I have left over. There is an oil feed hardline, a coolant feed hardline, half of the coolant return line (turbo side banjo fitting is cut off, rear section is there) and a used oil drain hose with clamps. Make me an offer for all of it? I switched to stainless braided lines. ![]() RB25DET/VG30DE(TT) OEM Thermostat - $10 Works great, removed to install colder Nismo unit. Includes free Permatex thermostat housing gasket maker. ![]() I am willing to ship any of this stuff, if you need a shipping quote I should be able to get you one within a couple days. I have a scale here and I just get quotes directly from the courier's website. I ship FedEx or USPS with tracking number provided the same day I ship. I ship everything from San Diego, 92101. Local pickup available. I accept PayPal on the condition that you add the usual 3% of the total cost to cover fees. Please post here or PM me with any questions. Thanks for looking!
-blakeZX | 1997 240SX SE (RB25DET), 2008 350Z Nismo Edition (VQ35HR)
Sent you a PM. Also forgot to mention I have a really clean stock turbo, I saw you were looking for one. I will list it when I have pics of it.
Added OEM turbo, gaskets, lock washers, and some random lines to listing, see photos above. Thanks!
Yes I do! I updated the thread with everything that is sold, so if it has a price that means I've still got it.
I don't have anything for sale apart from what is listed in my ads.. And the injector connectors are sold, sorry.
#21 |
i am interest in the banjo to an fitting, email me at [email protected]
#22 |
Hello, i wanted to know can you ship the Crossover pipe up to Québec Canada, i'll pay the shipping i dont care, i need one!
Please answer quick gotta find one quick to finish m build! Thanks! |
#23 |
That's not a problem, please PM me your postal code so we can figure out how much it will cost to get it to you. Thanks!
| ecu, fuel, oem, oil, rb25 |
