![]() Join Date: Nov 2008
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
s13 PBM multilink arms, 5 lug, aluminum knuckles, stock arms, subframe plates
Hi zilvia. I recently did all my rear subframe stuff arms/bushings/etc. I have some extra parts that I did not use or got better stuff in the process. Check them out below. I am most likely just shipping and not doing any local pickup as I work weird hours. All payment done via paypal. I usually ship via usps flat rate, so figure those typical 12-18 dollar shipping for most of these. If you need any info or more detailed pictures, just send me a message.
Powered By Max S13 Rear Multilink 550+Shipping These arms were off of my friends car. He had them for about a year and a half. All the nuts/adjustors/etc move freely and nothing is frozen. I took them all apart and put grease on them. If you are interested and need any more detailed pics please let me know. ![]() z32 Aluminum Knuckes with insert 100+shipping Oem set of z32 rear knuckles, and I made sure to grab the steel insert for the ball joint so they are ready to go. ![]() ![]() ![]() Rear 5 lug hubs 60+shipping SOLDD These are from the same z32. These hubs will fit on the rear of s13, s14, and I believe r32s and r33s. Please confirm before purchasing. They are in used condition, and have been sitting for a while. I cant feel any play in them. One of the studs was snapped so I replaced it for you. ![]() ![]() BNIB Gktech s13 v1 subframe reinforcement plates 30+shipping these are the original gktech weld in subframe brackets for s13. Would go great with the mazworx weld in diff plate in below. ![]() ![]() ![]() New Mazworks s13 weld in diff support 25+shipping This is brand new untouched. I don't have a box as it was just mailed in a bag. The marks are from them deburring in the machining process. Pretty thick gauge metal, and a perfect addition to the v1 gktech subframe plates above. ![]() Energy suspension rear s13 arm bushing set minus a few bushings 30+shipping SOLDD So this set would normally cover all the bushings in the rear multilink. Knuckle and arms. I took out 6 bushings from the set to do my knuckle. The knuckle and arms are the same bushings, only the lca are different. So what you have here is 4 lca bushings, and 6 multilink/knuckle bushings. So you can do the lcas and either the knuckle or the 3 other arms. If this doesn't make sense and your interested please contact me. Coincidentally this would do all the bushings in the below arms. ![]() ![]() ![]() ![]() s13 Factory Stock Rear arm set 80+shipping or 20+shipping a pair Stock arm set, in typical used condition. The ball joints don't have play, but have been ripped for a while. Id say rebuild them with new joints and the above bushing and have a solid spare set for the track. ![]() ![]() ![]() Last edited by Marino.; 06-11-2021 at 04:27 PM.. Reason: updated sold item |
