Viper 5704 won't start with key
I installed a 5704 in my 91 240sx
The car remote starts absolutely fine, but when I try to start the car with the key, ignition powers up but starter won't crank.
Heres the issue, when the pink ignition 1 input wire gets power, the starter kill opens, with no power there is continuity between violet and green, with power(ignition on) no continuity, i tested this with a dvom.
When I turn the key to crank I have 12v at green and at pink but 0v at violet
During remote start there's 12v at pink and violet
Red/white, red, and red/black--connected to white(constant 12v)
Pink-- connected to Black/red
Black/white cut in half---- violet/starter side-- green/key side
Any advice would really help, thanks.
