5lug conversion question.
I just got my ichiba 5lug conversion kit in. I took the new hub and made sure it fit in my 350z rims. The studs went in fine. But the ring that the tire sits on( idk what its called) is hard to get in the rim i pushed it and it went in. Taking it out thoe it was stuck took me bout a min to get it out. Should they be that tight? And ive herd these hubs are very common so someone should have a answer. Thank you
I think i migt be the studs go in perfect does the rotor have to be on? I was just seeig if they fit and relized that it gets stuck. I dnt have the rotors maybe that makes a diffrence. But yes there is a ring i guess and theres also a indention in the rims and it looks like it slides into them but mine is a little tight going all the way in. But is it cuz i dnt have the rotors on the hub frist ?
yeah bro i found the conversion hubs are the good simple way to go. if anything sometimes you need wheel spacers do to the stock 240sx rims being to narrow and now these 5 lug are much wider. check your rims for any imperfection around the stud holes. good luck
No dont think so the rotor on or off has nothing to do with the distance between studs. Im not 100% sure but eventho they are nissan rims nissan made some different bolt patterns.
will s13 rear 4lug hub bearing fit a z32tt 5lug rear hub?
if so ill be taking about the z32tt bearing and putting s13 bearing on can anybody comfirm or know it works? |
