![]() Join Date: Sep 2012
Tail lights help. S13 Coupe
Hey guys, so tonight I unplugged my battery to replace the negative terminal. Once I plugged back my battery and started the car I turned on my head lights and went around the car to make sure everything was cool and I notice that my tail lights have all the lights including my turn signals lit, but the turn signals still blink when I put on my emergencies on. This is my first 240 so please don't flame me. What should I do to correct this issue? All help is greatly appreciated.
That's a weird one. Be sure the tail light plugs are in correctly, then check your tail light and turn signal relays. To test these, get a friend to turn the headlights on, while you stick your face near the relays to hear them click. If they buzz or other weirdo sound you found your problem
