Old 04-19-2006, 11:32 AM   #1
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
Could the stock SMIC withstand track days?
Could the stock SMIC withstand track days without getting heatsoaked?
I need to find a solution to my "overheating" after 10 minutes... As long as it does not overheat before 20 minutes with a T28, it would be swell.. Of course, I'm talking about a SR20DET.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Driver: '08 Fiji Blue Honda Civic Si
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 04-19-2006, 01:13 PM   #2
93 240sxfastback
93 240sxfastback is an unknown quantity at this point
If you run only 7 psi you should be fine. If the weather is cold enough you can even run more.
On my T25g I ran 13psi on a cold night and after driving hard my ic was still as cold as ice. It really depends on the conditions.
93 240sxfastback is offline   Reply With Quote
Old 04-19-2006, 01:19 PM   #3
TheSquidd
TheSquidd's Avatar
TheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfectionTheSquidd is close to perfection
Send a message via AIM to TheSquidd
Ran all day at Streets of Willow at 7.5psi with no problems!
Other than that, might want a better SMIC.
TheSquidd is offline   Reply With Quote
Old 04-19-2006, 01:31 PM   #4
HaLo
from Canada, eh!
HaLo's Avatar
Yeah I'm thinking of getting rid of the FMIC... it blocks all air to the rad and the car starts overheating after 10 minutes on track events. I'm sure that with some water spraying, the SMIC could withstand much more....
-> HaLo
Old 04-19-2006, 01:32 PM   #5
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
you may be able to retrofit aftermarket SMICs for Z32s
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 04-19-2006, 02:08 PM   #6
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
is ARC the only one that makes aftermarket SMICs?
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 04-19-2006, 02:32 PM   #7
HaLo
from Canada, eh!
HaLo's Avatar
I saw a Blitz unit on ebay too!
-> HaLo
Old 04-19-2006, 02:35 PM   #8
EchoOfSilence
actually you should check out splparts. Kuah has quite a list of SMIC's he sells. ARC has the biggest dimensions, though
EDIT: he only lists two that he sells, but lists the dimensions of the competitors
Old 04-19-2006, 02:38 PM   #9
HaLo
from Canada, eh!
HaLo's Avatar
I haven't seen anything on their website, might have to send him an email.
-> HaLo
Old 04-19-2006, 03:23 PM   #10
EchoOfSilence
http://splparts.com/Parts/Z32/Turbo/IC/default.asp
there you go, man. You should still ask if you can retrofit for use in an S13 though.
Have you thought of a V-Mount application?
Old 04-19-2006, 03:28 PM   #11
HaLo
from Canada, eh!
HaLo's Avatar
I thought about it, but it requires way too much custom fabrication, cutting, etc... I don't want to do that to the convertible... Hell, I'd swap a VQ35DE instead of doing that.
-> HaLo
Old 04-19-2006, 05:21 PM   #12
EchoOfSilence
what about routing the fmic to behind the rad?
Old 04-19-2006, 05:26 PM   #13
HaLo
from Canada, eh!
HaLo's Avatar
Wouldn't that create another problem: FMIC not cooling the air properly?
-> HaLo
Old 04-19-2006, 05:33 PM   #14
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
What are the dimensions of the stock side mount compared to a s15 sidemount? I'm sure an s15 sidemount or an aftermarket replacement will suffice. An s15 sidemount shouldn't heatsoak in 20min. unless your running over 300hp and/or it's really hot out.
spdfreek0o is offline   Reply With Quote
Old 04-19-2006, 07:44 PM   #15
EchoOfSilence
s15 sidemounts are much beefier... Mr.Mephistopheles had a writeup a while back
Old 04-19-2006, 08:26 PM   #16
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
your doing autox right? I just dont see overheating at any open track day unless there is some other problem, that or your going slow and high revs (autox). I dunno, neither my oil or coolant ever go over 110C even after like 10 laps.
Old 04-19-2006, 11:18 PM   #17
Dutchmalmiss
i think the s15 smic's are about 1cm thicker. would that even make a diff?
Pignose, biaaatch.
Old 04-19-2006, 11:47 PM   #18
EchoOfSilence
it's more than that, IIRC. the endtanks are a different design too
Old 04-20-2006, 12:06 AM   #19
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
#/f/showthread.p...15+intercooler
Here's the important snippet:
Originally Posted by me
Here are some comparison pics:
As you can see, the surface area of the core is the same, while it's about 10mm thicker. I didn't get a thickness measurement, but it can easily be obtained at a later time. edit: should be S13 = 5cm, S15 = 6cm.
The thickness will make a difference. That 1cm is a 20% increase in volume right there. The end tanks seem over-widened compared to the S13 cooler to take advantage of the greater volume.
Originally Posted by PHLIP
Old 04-20-2006, 08:24 AM   #20
HaLo
from Canada, eh!
HaLo's Avatar
Street: never overheats
Auto-X: never overheats
Track/Lapping: Overheats after 10 minutes of hard driving
I don't have an oil cooler: could that fix the problem?
I have a FMIC that fills up by S13 front end opening in front of the radiator.
S15 / ARC SMICs are VERY interesting... I just want to be sure that's gonna solve my problem.
-> HaLo
Old 04-20-2006, 02:26 PM   #21
EchoOfSilence
hell YES an oil cooler will help.
Old 04-21-2006, 02:40 PM   #22
Dutchmalmiss
yes s15/ARC smic's do sound interesting as well, but where the hell can we find some?!?!?!
Pignose, biaaatch.
Old 04-21-2006, 05:16 PM   #23
Omarius Maximus
Omarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of light
Yeah I'm pretty sure it'll get heat soaked. It all depends on how much power your making.
Omarius Maximus is offline   Reply With Quote
Old 04-21-2006, 08:06 PM   #24
HaLo
from Canada, eh!
HaLo's Avatar
www.upgarage.com
as for the getting heatsoaked: at 250whp, i doubt it.
-> HaLo
Old 04-22-2006, 01:10 AM   #25
Omarius Maximus
My friend has a GTI 1.8t with a chip and tbe, and he heatsoakes his side mount all the time. Hes probably has 30 or 40 less hp and probably the same intercooler size. It just depends on a variety of things. How long you run the car at full throttle as well as whether your running the turbo in it's efficiency range. If your around stock boost I wouldn't worry about it either. Your running 550 injectors right? TBE, intake and a tune? How much boost are your running out of curiosity?
Old 04-22-2006, 01:29 AM   #26
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
How come everyone with an sr with this question has no idea that it is their OIl temp that creates this problem.
If the cooling system has an adiquate size fan, and a good thermostat.
blu808 is offline   Reply With Quote
Old 04-23-2006, 12:30 PM   #27
Dutchmalmiss
Originally Posted by HaLo
any sites with english as the language?
blu808, would upgrading the thermostat be necessary?
Pignose, biaaatch.
Old 04-23-2006, 03:22 PM   #28
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
I've never had this problem on an sr..
OIL cooler is a big +
Also, you said you are running a smaller t25, but a BIG Front mount, maybe get a shorter front mount that hooks into you're piping, to let air pass to the radiator.
I have good pricing on PWR intercoolers and radiators. Not as cheap as the ebay xs power, or koyo.. but WAAAY better quality. Better as in No 1 Ic/RAD for import drag and V8SuperCar!
Send me a p/m if interested.
john
[email protected]
johngriff is offline   Reply With Quote
Old 04-23-2006, 05:02 PM   #29
bobcat
bobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to allbobcat is a name known to all
maybe thisll help
i have a blitz upgraded smic with a 5-zigen cold pipe and an hks hotpipe w/ bov. I have a redtop s13 sr with a 1.2 greddy head gasket, greddy intake manifold, stock exhaust manifold with rebuilt stock turbo, HKS evc2 boost controller, stock computer, stock injectors, 85mm turbo back with test pipe, hks super mega flow intake, stock radiator, and stock fan with shroud. I ran on streets of willow this last friday. The air temp for the day was averaging 78 degrees. I ran 13.8 psi of boost all day long without any overheating problems or heatsoak on the smic. My smic got slightly hot when i did a 3 lap time attack of 17.2 psi. upgrading the sidemount is great but not nearly as great as a fmic. I kept the smic setup to be sleeper in the cops eyes. I have almost 275 hp @ 16.5 psi :P
bobcat is offline   Reply With Quote
Old 04-23-2006, 08:18 PM   #30
rossfashow
rossfashow's Avatar
rossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura about
PWR Intercoolers!!! I have one on my 89 s13 18x6x3. great size!
rossfashow is offline   Reply With Quote
