Old 07-18-2012, 09:46 PM   #1
Typecast
Typecast is an unknown quantity at this point
fresh swap---s14 sr won't crank
got it going please delete
Typecast is offline   Reply With Quote
Old 07-18-2012, 09:49 PM   #2
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
im assuming your grounds are all hooked up? not just attached with a loose bolt...?
i did that once. took me a while to figure out the ground on the back of the head was loose.
AsleepAltima is offline   Reply With Quote
Old 07-18-2012, 09:51 PM   #3
Typecast
i will check the one on the back of head thank you, as well as all others. I believe they are all good, but i can go over them again
thanks buddy
Old 07-18-2012, 09:55 PM   #4
AsleepAltima
hopefully thats what it is. grounds are a bastard to sort out sometimes.
Old 07-18-2012, 10:15 PM   #5
darkroom1428
darkroom1428 is an unknown quantity at this point
I would start with the clutch sensor. Make sure the trans is in neutral and above the clutch pedal you will find a sensor push in the sensor and turn the key. If the starter kicks on its the pedal bushing to press in the sensor.
darkroom1428 is offline   Reply With Quote
Old 07-18-2012, 10:18 PM   #6
Typecast
we have bypassed the neutral safety switch. But I will check that as well
Old 07-18-2012, 10:42 PM   #7
Typecast
also while trying to crank the engine the starter signal wire seems not to have power to it.
Old 07-19-2012, 06:01 PM   #8
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
did you bypass the park switch under the hood? you said it was auto before. you need to jump that switch out as well.
godsmack is offline   Reply With Quote
Old 07-19-2012, 07:55 PM   #9
Typecast
----Update----
i jumped the ignition with a remote start button and it cranks, but it doesn't fire.
I did acouple more things and found out my ignition switch where the key goes in is bad. so that problem is solved.
now the problem is cranks but doesn't start
i have checked power to the number one coilpack and to the fuel injector they get power.
