![]() Join Date: Feb 2005
Weird misfiring on cold start up + a weird AFC/MAF issue.. (RB)
Figured I'd combine those issues into one thread.
Got an RB20. Important mods included GT32, Knockoff Intake Mani (iffy about), Apexi SAFCII ( which I hate ), Tomei Poncams, Deatchwerks 440CC injectors, Megan FPR, and a Z32 MAF. And being monitored by Zeitronix wideband. Issue 1: I set the AFC to 2 in 4 out for the maf. but as soon as i applied load to the engine it cuts out and surged like crazy, afr's all over the place and i cant make it to 3000 rpms. I reset the AFC to 1 in 1 out.. the car runs great. Here's my Zeitronix log when tuning in that setting I've tried a different MAF, ECU, and grounds. I dont have a EBC or anything right now. So that chart is on only 3 psi tops, due to my exhaust mani and wastegate (I presume). Under boost the afr readings are from 11.5 to 12.5ish, at idle 14.5 to 15. Issue 2: From some reason at cold start ups, it hesitant and misfires if I try to drive it, quite bad. I dont have a graph for whats going on with my afr when that happens right now. But I dont think thats it. But if a start the car and let it idle for like 10 minutes, its fine. I searched and couldn't come up with anything. Possibly wrong wording. If so my bad. But any help is great. |
Why do you have an AFC if you hate it?
Have you thought about an L-jetro PFC or a tuned ecu even? -Either way. What are stock RB20 injectors? A GT32 turbo would require at least 550 cc imo. Also your Z maf should not be running so smooth with 1in and 1out settings, is that not the same as stock? Or could it be the RB20 voltage for the RB20 MAF are very similar in range to the Z32 so it runs close to stock when warmed up and in the primary maps, but shitty when in the colder.lower load regions of the startup/warm up side of the map. Just some things to think about . Also make sure you have the right plugs (heat ranges and gap).
Like Me on FaceBook !
- hayai - I'll try setting it to 4-4 tomorrow (if i can remember before work) thanks for the input |
