Q45 rear diff questions
I just wanted to make sure I've done my research right before I started buying parts.
For a 97-01 Q45 rear diff I can use 92-94 j30 axles one driver side and one passenger side. Which hubs should I be looking at. For a 90-94 Q45 rear diff I can use a 300zxtt driver side axle and a 90-94 Q45 driver side axle. And 90-94 Q45 hubs Sent from my D6708 using Tapatalk |
![]() Join Date: Feb 2016
im pretty sure if u have a q45 diff with the 1x6 hub bolt pattern u can use stock z33(350z) axles on ur S schassis since the stubs are the same spline to the spindle. people do like s13diff to z33 axle conversions using an adapter but if u already have a q45(IF you have it) you shuold be able to get away with it
So I just found a 94 300zx tt driver axle and both hub assemblies with spindles for 300. Does that seem like a good deal? it also come with the 300zx tt rear knuckles. That I'll probably sell.
