350z wont start
dash lights up everything works but when u turn the key to start it the dash goes dim and nothing happens not geting power to fuel pump or starter is there anyone here that can help me out? Thanks
![]() Join Date: Aug 2010
Make sure your battery is properly connected. Just because its new doesn't mean its connected properly.
MAKE SURE THE TERMINALS/GROUND ARE ON CORRECTLY
#6 | |
How much gas in the tank? Have you checked if the pump is getting power?
#8 | |
If its above 12.6 (I think) Then check the voltage at the starter.(Should be the same) If it is than give your starter a wack on with a hammer. Then try to start it. Seems like your having an electrical issue.
