![]() Join Date: Jul 2006
if you are using them on a rb 25 <--- with a greddy front facing style intake, you will need to get spacers from fuelinjectorclinic.com to get them to work. 25's are side feed injectors, so i found a mod to take deatchwerks style top feed injectors (like the ones for sale) to work!
If you are using them on a rb20 or 26, then it is plug and play, since they already come top feed. |
well yeah, they are 11 mm top feed injectors. Snag a 11 mm top feed rail and its plug and play for a Rb20/26 . For the 25, you still need the adapter for the injector ports (from the site noted), to make them fit into your manifold. Once again the rail will fit any injector as long as its the same diameter top (10mm to 10mm, 11 to 11)
