Old 04-23-2013, 04:24 PM   #61
Bumpkin203
Bumpkin203's Avatar
Bumpkin203 is an unknown quantity at this point
I like the simplified wiring, inspiration for me to do something similar in the future.
Instagram @bankai_r32
Bumpkin203 is offline   Reply With Quote
Old 04-23-2013, 07:17 PM   #62
pigeon
pigeon is an unknown quantity at this point
Love the engine bay and red valve cover. merica
pigeon is offline   Reply With Quote
Old 04-24-2013, 06:57 AM   #63
PoorMans180SX
PoorMans180SX's Avatar
Looks really good man. The low mount power steering is a cool idea!
Old 04-28-2013, 06:53 PM   #64
KoukiMonsta
KoukiMonsta's Avatar
Originally Posted by supersayianjim View Post
kick ass build!!
thanks!
take time to learn the fsm and its no big deal.
Merica'
thanks man, love your build
Ok so last post i had this fucking genious idea to mount the electric bs in the glove box. That plan has since been trashed. basically the space retrictions were kiling me, it got super cluttered super fast.
so i did some thinking, and some drinking, and came up with this even sillier idea. i rele liked the idea of using the glovebox to hide it all. i gutted the box itself and will just be using the front portion as a 'door' to the fuses and such. everything is mounted to a piece of wood i had laying around... so far seems like a much better plan.
may have gone overkill on relays, better safe than sorry. i separated as much of the electric systems as possible in the whole build. this way when issues occour its easy(er) to troubleshoot where the problem is.
this is on the passenger floor, always ends up looking like a mess...as per usual im not a pro..
i dont have any pictures, but i wleded up some brackets to the dash bar the plywood bolts too. turned out fairly well. i like it....for now
notice ignitor location
at this point ive got power to the ecu, engine, starter, and fuel pump.
lights, cluster, etc will be coming soon.
fluids in the car, brakes and clutch bled!
Lets also note the bay is fully wired! Pretty well tucked, no ugly brake lines on firewall. But that damn booster line is still there. Throttle cable bracket is a mockup, and the cable is too. Need a s14 or dohc cable since this is a sohc car it's too short I just put it in for looks..doesn't connect.
shits about to get real! stay tuned ladies and gents
@UpshiftEngineering
Old 04-28-2013, 08:39 PM   #65
Bumpkin203
Bumpkin203's Avatar
That bay is so clean man!
Old 04-29-2013, 10:59 AM   #66
KoukiMonsta
not a real update, some pics that never made it.
dont think i mentioned it, no wiring runs through the wheel wells. headlight and fan come up the passenger frame rail. all the wiring goes through the ac water dump tube hole, almost out of sight. its amazing seeing the space under the fender since i cut it all up too. hopefully no rubbing.... and very low is the plan
In these pics there's no wiring..
@UpshiftEngineering
Old 04-29-2013, 11:07 AM   #67
Bumpkin203
Bumpkin203's Avatar
Like i said lol
Old 04-29-2013, 11:51 AM   #68
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
clean tuck
Old 05-11-2013, 10:00 AM   #69
KoukiMonsta
***A bit of an update, few pics for your viewing pleasure.
Picked up this boost gauge
Ive got this rediculous shit going on, cannot wait to be past the wiring phase
factory fucking bumper! now thats sweet not haveing a massive FMIC like previous setups..
bumper on, lights work!
Man its the little things that seem easy and really start to add up once your finally trying to get it started. We are getting very close though!
shameless plug - someone buy my FS junk so i can keep working on this!
@UpshiftEngineering
Old 05-18-2013, 12:21 PM   #70
KoukiMonsta
*****This update is kinda a big deal guys*****
cluster and gauges have power, blue leds will be swapped for white ones. the red "11.5" is a voltage reading, just a digital display i epoxied into the cluster
So at this point it is time to give the first attempt at starting the motor! fingers crossed my wiring is correct....
and it doesn't start...
starter turns, fuel pump is on, pressure at rail...after a bit i smell fuel
turn it over some more, backfire loud as hell.
at this point i begin to think about the ignitor wiring, essentially firing order. i found 2 sources of contradicting info on which color wire is what cylinder. decided top de-pin and swap cylinders 1 and 2...
FIRED RIGHT UP!!
Whats a better way to host videos? my usual flickr account is "full of videos" for basic user..cuz that site sucks balls
didnt leak any oil which is cool, busted a coolant hose as soon as some pressure was built after bleeding..also need a new brake booster.
So at this point im pretty pumped that the motor is running, but ive got a big issue...the head was never really serviced, it previously overheated, valve guides are worn, and leakdown proved lots of leakage past valves..
it is evident the motor has low vacuum (~10 in hg) and a leakdown did verify its from the head. So this is sorta shitty, but i expected it. the head will be serviced via Mazworx, slap in on with new apexi HG and we should be rolling..but thats gonna take some time.
In the mean time i will begin working on the interior, got some good stuff in store.
@UpshiftEngineering
Old 05-30-2013, 05:04 PM   #71
KoukiMonsta
******Update
Glad I am the only one excited this POS started haha.
I pulled the head, heres some pics..helps to show how i did some other stuff too.
hit the pistons with acetone..yay shiney
the problem...
The head will be sent to Mazworx like i said. then this sucker should be better than ever!
Ive been working on the interior, but you will have to wait for that.
@UpshiftEngineering
Old 06-05-2013, 09:42 AM   #72
SuperLame
SuperLame is an unknown quantity at this point
Awesome build so far. What are the plans for the exterior?
SuperLame is offline   Reply With Quote
Old 06-05-2013, 12:27 PM   #73
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Sick ass build bro! Can't wait for more updates this is a very inspiring build to say the least.
S14Serge is offline   Reply With Quote
Old 06-07-2013, 04:56 AM   #74
KoukiMonsta
Thanks man! Helps me keepin going
I've always loved the kouki/type x look. But there's also a couple kits I like. It won't be super huge widebody aggressive aero. Something more 'simple' really not sure yet
@UpshiftEngineering
Old 06-07-2013, 02:50 PM   #75
taran!
taran! is an unknown quantity at this point
Love the build man, can't wait for more updates. You bought my buddies shell, so im happy to see that you are putting it to good use and it is turning into something rad.
taran! is offline   Reply With Quote
Old 06-09-2013, 09:25 PM   #76
KoukiMonsta
thanks man, one day i hope its rad thats for sure.
*******UPDATE
as i said been working on re assembling the interior. it was in pretty good shape when i got it. clean carpet is awesome.
sprayed some rattle can tpo get it all one color, removed rear sound deadening
seats and carpet in
rear seats too
got to work on something for my gauges
gave it some texture
test fit looks good
applied power for fun, got some ABS plastic to get a switch panel going
finished product
something im working on thanks to inspiration from broadfield. never was a fan of those hideous buttons
@UpshiftEngineering
Old 06-11-2013, 07:29 PM   #77
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Feedback Score: 163 reviews
I'm curious to see what you got going on there.
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 06-11-2013, 08:01 PM   #78
KoukiMonsta
I first checked the interior thread, and then the build section. Where I found 2 posts you made..
The first being and amazing cluster surround you made. Which is superd sir, I debated putting my wideband in one of the vents. Ultimately decided against it due to being too low, to look at while hammering the throttle!
My plan is way more basic, and I am not good with filler/sand/fill/sand type thing... It's far from perfect, but as per my usual mantra it's my first time.
Stay tuned finished product soon.
@UpshiftEngineering
Old 06-16-2013, 09:15 AM   #79
KoukiMonsta
*********UPDATE
here are some process pics from the cluster surround piece, turned out kinda cool i think. definitely not perfect...who cares
finished product, if you look hard enough/from the right angle you can kinda see the original cutouts, i need to up my filler/sanding skills or some shit
headliner had all kinds of funky stains
so i died it
interior just about complete, my door panel suck though...
@UpshiftEngineering
Old 06-16-2013, 09:45 AM   #80
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
That dash button delete turned out pretty slick especially for just keeping it simple like you did. Nice work on getting the pig fired up as well. Too bad your glove box setup didn't turn out like you originally hoped, that's a bummer. It turned out far better than mine did. I just half assed it to get it running and racing, because I'm a lazy shit. When will you hope to have the headwork finished and back together? Keep it up, I like that it is getting cleaned up from the inside out.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 06-21-2013, 04:41 PM   #81
KoukiMonsta
Thanks man
Really the glovebox thing turned out just fine. In the end it's a much better design.
It will be up and running very soon...apexi HG to seal it up.
image by Koukimonsta, on Flickr
@UpshiftEngineering
Old 06-21-2013, 05:50 PM   #82
WristWork
WristWork's Avatar
WristWork is an unknown quantity at this point
It looks funky without the buttons, why don't you just shave the sides completely flat? Would look much cleaner imo.
Loving this build so far
WristWork is offline   Reply With Quote
Old 06-21-2013, 05:51 PM   #83
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Everything looks pretty damn good so far. I wish I would've gotten rid of more creature comforts in my car so I could take the wiring down to an extreme, but it should work for now.
Keep the updates flowing.
My SR20VET
jr_ss is online now   Reply With Quote
Old 06-21-2013, 08:40 PM   #84
Shanevasquez
Shanevasquez is an unknown quantity at this point
Nice build!!!
Shanevasquez is offline   Reply With Quote
Old 06-22-2013, 03:00 PM   #85
KoukiMonsta
That's not a bad idea, I took a simple route since it was on a whim. Possible future changes will be made. Thanks tho man!
Yea the super simple wiring was a must have for me. It's straight essentials nothing else. Though damn ac would be fucking awesome.
I've said it before, can't fucking wait to hear your setup! Hope to see it in person one day. Thanks for the kind words, and help diagnosing my low vac issue.
Originally Posted by Shanevasquez View Post
Nice build!!!
Thanks man!
Update coming soon, until then fdnj live feed.
@UpshiftEngineering
Old 06-22-2013, 03:54 PM   #86
jr_ss
Trader Rating: (34)
So did Mazworx have anything to say about what the issue was with your head or did you just have them go through the entire thing? Curious what the issue at hand was in that last thread(low SR vac).
My SR20VET
Old 06-22-2013, 04:37 PM   #87
KoukiMonsta
After a couple conversations with mazworx (along with input from you and a couple other guys) it was clear the head was at fault.
Tore it apart, found excessive play in valve guides. And 2 bent valves. At that point it was clear, it needed some attention.
The valves weren't seating and sealing properly, thus not creating vaccum, compression, or leak down numbers up to spec.
So do it once, and do it proper. (Crosses fingers) at this point I should have everything ready to make some solid power. But there's always something.
@UpshiftEngineering
Old 07-08-2013, 01:00 PM   #88
KoukiMonsta
**********Update
The drivers side e-brake cable snapped on me, easy enough to replace but still dumb
I picked up this aluminum sheet...
and created this cooling panel
seems like it should delp direct air through the rad instead of over
this was a beautiful sight. valve job and freshly decked by Mazworx!
this showed up, its an 8815
headgasket in place, dont think i ever posted the PS high pressure line i made, here it can be seen. thanks to Toby for XRP materials, awesome stuff
now its coming along
I also did a manual seatbelt conversion, using the original interior panels
extended bolts were made up
s13 belts used, modified panels
very good phot here...
picked up this bulkhead fitting for my main starter power wire, you can also see clutch line routing
@UpshiftEngineering
Old 07-08-2013, 01:08 PM   #89
KoukiMonsta
*******Bonus Update
during the head installation my buddy setup the go pro to take a pic every minute, turned out kinda cool. made this sweet edit for me
http://www.youtube.com/watch?v=Dk-tKJzzMJM&feature=youtu.be
@UpshiftEngineering
Old 07-08-2013, 03:58 PM   #90
alexander240
alexander240's Avatar
alexander240 is an unknown quantity at this point
How long are you oil relocation lines?
WTB: Dmax Coupe roof spoiler.
alexander240 is offline   Reply With Quote
