#271 |
2UP S13 Clear Headlight Covers - 2UP Japanese Styling it comes with instructions on how to strip the old lenses off it was easy as
#272 |
![]() Join Date: May 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
are you LED mod guys running individual resistors to each of the led's? and what rating resistor you using.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
#273 |
its not good to run them like that
in my tail lights im using one resistor for every 4 leds use this site LED series parallel array wizard |
#275 |
![]() Join Date: Apr 2006
my wife looked at that photo and said, in her wonderfully broken english
"what is it inside that, some tube?" yes indeed. some tube. this thread is so awesome. |
#276 | |
![]() Join Date: Jun 2010
#280 |
#281 |
What is the best way to make the low beams stay lit while the high beams are activated on an S13?
I know it has been discussed countless times, but I assume the light masters will know best. One supposed method that sounds most simple and appealing is to use the pop-up headlight motor wiring as the power source for the low beams (the headlight motors would not be used). Apparently it sees constant power whenever the low/high beams are on, plus it already has its own relays and fuses. The high beams would remain wired normally. Can anyone confirm if this method works? |
#282 |
![]() Join Date: Oct 2007
Trader Rating: (53)
This is what i used to wire my headlights when i converted to bricks from pop-ups. it tells you which wires to splice together to keep both beams on. Unfortunately the pics arent up anymore.
Installing Silvia Non-Projector (Brick) Headlights : 240sx Articles |
#283 | |
'98 240sx 5spd |
#285 |
![]() I know for a fact this harness works for h4 so your low and high will stay on at the same time. I use them for my s14 zenki retros Bi-xenon: 'MotoControl 9003/H4/HB2 - Relay Harnesses from The Retrofit Source Inc
'98 240sx 5spd |
#286 |
Looks real nice. What projectors do nsx's use? Is it a small d2s kioto with the black plastic lens holder? Get some clear headlight lenses on there if you can.
'98 240sx 5spd |
#287 | |
#289 | ||
My headlights will have separate low and high beam projectors, so it will be more similar to wiring S15 headlights on an S13. I have been searching for ways to keep the low beams on when the high beams are activated, and stumbled across this: Quote:
Is this the plastic piece it talks about? I am not quite sure what to notch. ![]() ![]() ![]() |
#290 | |
![]() Join Date: May 2003
Xenon (HID) retrofit Granted, this applies to the s14 switch but the principle should be the same for the s13. Hope that helps...
**The atypical S-chassis enthusiast*** |
#291 |
So I fitted these projector foglights I took off of a lexus at the junkyard and installed them on my car and surprisingly its a direct bolt on for the s13 pignose besides wiring and buying longer bolts for bracket to work. I don't know if all pignose bumpers come pre drilled but mine was and the install was fairly easy I'm loving them
Onto what you guys wanna see PICTURES: |
#293 | |
![]() The output of them is supposed to be terrible, which is exactly why. I never really use the high-beam anyway, so I would mainly just like to figure out a good way to make it look lit along with the low-beam, without blinding people. I have also considered hiding small LED's as 'running lights' inside the projector housing, but at the same time I do not really want to cut up and ruin the headlights. My other idea is to use two low-beam projectors. Would it be alright to use a low-beam projector in place of the high-beam one in a headlight housing, or does the shape of the outer glass play a role as well? |
#294 | |
Trader Rating: (50)
#295 | |
![]() Join Date: Mar 2008
![]() ![]() Feedback Score: 1 reviews
#296 |
Yeah this is what they look like with bracket
Sent from my T-Mobile myTouch 3G Slide using Tapatalk 2 |
#298 |
just out of curiosity... would any of you recommend some decent priced LEDs to PRACTICE with... something cheaper than the high quality stuff im finding so i can practice and then if i get the hang of making decent stuff...
#300 | |
![]() Join Date: Aug 2006
Superflux LEDs will also look 1000x times better than 5mm leds when finished... Unless you like the lite-brite look with terrible viewing angles. |
