wiring help: Sr20 Notch top into S14
I've been searching for wiring help on a notch top engine into a s14 chassis but can't find anything or post was too old that the photos does not exist. but as of right now, on my lower harness, I have two plug that is suppose to plug into the main fuse box not matching up. my KA harness have a different oil pressure sensor plug. so i wasn't able to use that.
![]() -two upper plug are the SR jdm harness, the bottom is the KA harness ![]() -the two lower on is the plug coming out of my fues box. any help is appreciated. |
Hopefully someone responds quick with good knowledge. If you get fed up though I'm selling a wiring specialties harness for an S14 SR into S14 chassis
![]() Join Date: Jul 2005
You use the KA lower harness from your old KA engine on the sr20det
nobody needs a special lower harness unless they are relocating or wire tucking/updating plugs |
