Cooling panels
General question: I have a Stroker 402 ls swap and wondering how many out there are running cooling panels in their cars. Top and bottom. Reason I ask is because at idle or in heavy traffic my engine temps will creep very slowly 1 degree every two or so minutes which tells me I may have a engine heat ventilation issue. Once i start driving temps subside back to 180-190 Ish. Here are my cooling ancillaries.
-Mishi radiator -Two dual spal 12 inch puller fans approx 4K cfm. On at 185 off at 170 -160 motorad t stat -gto water pump. -rear blocked off coolant lines front connected to overflow tank. Sent from my iPhone using Tapatalk |
![]() Join Date: Jul 2005
4 steam ports need to run to the top tank of the radiator. Do not block rear steam port lines.
if not running a heater core, block the heater lines in the water pump with tap and plug. Do not loop. Use high quality fans, I used Altima 93-97 fans (ebay $75) and a throw-away aluminum radiator (ebay $90) and my LS swap stays cool running only 1 fan. And I am single turbo, exhaust pipe runs all over the engine bay. |
#9 | |
One more question: what is your current engine temp at idle and while cruising? |
