Old 05-03-2019, 06:02 AM   #1
akruger34
akruger34 is an unknown quantity at this point
550 Denso setup
I was given these injectors in a box with my SR swap, I am trying to get them set up for a new turbo. My questions are:
Do I need to run the blue brackets?
Do I need an o-ring on the tip? I've seen some that have them and some that don't. The middle ring seems to be at the same level as the oem.
When I rewire these for the new plugs, are the wires/pins in the same orientation as factory?
http://imgur.com/ReZvCwh
http://imgur.com/gZBKuS9
akruger34 is offline   Reply With Quote
Old 05-03-2019, 06:04 AM   #2
s13silvia123
s13silvia123's Avatar
test fit them with and without, and see what happens
