Closed Thread
Old 02-13-2013, 05:31 PM   #121
cchondro
cchondro is an unknown quantity at this point
Love the build man
keep it up!
cchondro is offline
Old 02-13-2013, 10:27 PM   #122
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
I actually made a grill like that 3 yrs ago for my silvia front, better airflow is all i wanted. I really cant wait to see this painted!!
JohnnyDrfiter22 is offline
Old 02-14-2013, 12:47 AM   #123
Miguelone
Miguelone is an unknown quantity at this point
I read what you said about grille but Nismo grille would look dope imo.
Miguelone is offline
Old 02-14-2013, 12:22 PM   #124
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
Car looks lame. You should get rid of the Volks for XXR's and and PBM stuff for Godspeed. Then yout car would be proper.
JK! I think the followers will like the new updates coming. Keep it up Max
Driven08 is offline
Old 02-14-2013, 05:39 PM   #125
Extreme Dimensions
Extreme Dimensions's Avatar
lol
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Extreme Dimensions is offline
Old 02-15-2013, 09:59 AM   #126
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Haha thanks guys, and thanks eric yeah I think they'll like this brief but GREAT update
okay so around the time I put my car down to "fix my issues" I bought a sr off a buddy of mine, which I had planned building up.
I opened up the block and saw that the bottom end was trash, so I did just that and trashed the bottom end. The head though had all kinds of good stuff so I kept it. Found a fresh block bored over .20, got some wiesco pistons and a fresh crankshaft. So I was set on building the engine. I had been gathering all of the missing ends to complete it but as time draws nearer to my "due" date, I won't be able to go ahead with that set plan. Instead I did something to help me finish alot faster..
Yes I bought a running sr with slight mods: Tomei Pon Cams 256/256 , Apexi 1:1 Hg, Greddy oilpan, and a Tomei N1 Oil Block. Not much but as you can see I already bolted on most of my stuff. As a result of this I have some stuff forsale! #/f/sale-items/50355...-sr-cheap.html
You can see I also have a s13.4 vc I had painted it wrinkle black then sprayed red over it but didn't turn out how I planned so Polished for now is what I'm going with.
So whats all thats left to finish this build you ask? ALOT, but what is left to get this running and semi done? Just have to go pick up my Power FC, Z32 trans, and Clutch that I've had on hold for a bit. Then just paint it. I'll be using a welded diff due to time constraints, but like i said this is only to get it semi done for the event. I should be done by the end of march so I'll be keeping my fingers crossed!
CleanAndLegit is offline
Old 02-15-2013, 11:44 AM   #127
Twinkies!
Twinkies!'s Avatar
Twinkies! is an unknown quantity at this point
this build is making me wet!! your coupe is coming together nicely, have you picked out a color choice yet or what?
Twinkies! is offline
Old 02-17-2013, 07:17 PM   #128
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
This build delivers! Love the work keep it up mayne!
S14Serge is offline
Old 02-17-2013, 09:00 PM   #129
CleanAndLegit
Trader Rating: (55)
Thanks guys!
So today I pulled my lcas off the car and worked on them some more.
As you can see there was already material missing from them.
I used that to make the notch
then cut out the fill in pieces from some sheet metal
and also cut out the boxing in pieces
hopefully this week I can get everything welded up so I can start the pre alignment to ease it up for the tech. I also decided to go ahead and install the lines for my heater core on the sr, Previous owner had deleted his heater core, I will be using it.
Cut this off
Add these
and you get this
after I was done with that I pushed the car out and rinsed it down, it was getting really dusty. Also sweeped the garage.
Old 02-18-2013, 01:35 AM   #130
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
you should put a bead on that heater line while the engine is out, cause when it pops off later on its not gonna be fun.
huffandpuff00 is offline
Old 02-19-2013, 12:01 AM   #131
CleanAndLegit
Trader Rating: (55)
Will Do! Thanks for the heads up.
Old 02-19-2013, 03:18 AM   #132
TheRealSy90
TheRealSy90's Avatar
Weld my lca's for me
Such a good signature.
TheRealSy90 is offline
Old 02-19-2013, 08:22 AM   #133
PG BOOSTED
PG BOOSTED is an unknown quantity at this point
sell me yours sylas
-Alex Bailey /18/ Orlando, FL / ⭐Founder of Straight Six Gang⭐
PG BOOSTED is offline
Old 02-19-2013, 10:10 AM   #134
CleanAndLegit
Trader Rating: (55)
I wish I could weld that nice but with the lack of proper tools and technique I can't my buddy Juan Vargas over at BARDABE PERFORMANCE is doing most of the viewable welding. anything that can't really be seen I'm attempting haha.
Old 02-19-2013, 11:08 AM   #135
pacotaco345
pacotaco345's Avatar
+1 for Juan, he's the Juan to go to for fabrication lol
pacotaco345 is offline
Old 02-25-2013, 10:18 PM   #136
CleanAndLegit
Trader Rating: (55)
Haven't done much but a bigger update will be coming soon.
Test fitted the rear 50mm overs to see what kind of gap I would be dealing with and it wasn't as bad as I thought. I think I'm going to be using bolts to mount as the holes I had drilled aren't that far off and will be annoying using rivets due to the holes having to be slightly enlarged. You can also see the shitty driverside fitment (I'm not sure as why its not the same as the passenger side but its annoying trying to fix)
In this last picture you can see the piece they cut off when the overs were bowed out by the previous owner of them.
I also wrinkled my Valve cover and will finally be sealing the motor for good.
That's about it.
Old 02-25-2013, 11:09 PM   #137
Twinkies!
Twinkies!'s Avatar
Your car is definitely one of a kind, I love those tomei corner covers that look awesome, keep it up
Old 02-26-2013, 12:14 PM   #138
DialedLife
DialedLife is an unknown quantity at this point
wow that is a nice coupe.
DialedLife is offline
Old 02-27-2013, 11:51 AM   #139
cchondro
Nice update
that valve cover came out beautifully
cchondro is offline
Old 03-01-2013, 10:04 AM   #140
CleanAndLegit
Trader Rating: (55)
Thanks guys, I'm happy with the valve covers outcome looks great.
So this week has been pretty great. I picked up my ORC Super Single Clutch, and My z32 Trans, along with a welded diff and Greddy/Trust turbo elbow. I'd like to go ahead and thank Chris "Flybert" for being such a cool dude and hooking me up with awesome deals THANKS!
So I didn't have anybody helping so I didn't get many pictures but here they are;
ORC Super Single
Adapter Plate
Z32 Mated
I was scared thinking my dump tube was gonna be hitting the trans but nope it cleared no problem.
So as I mentioned I went with a welded diff to fund constraints I'll be saving and buying a Cusco 1.5way after it's painted and running correctly.
And the aftermath
Huge mess but thats about it for today, was hoping to have more pictures for you guys but I was doing this alone and didn't have the clean hands to shoot.
Old 03-01-2013, 12:47 PM   #141
KravingAKouki
KravingAKouki is an unknown quantity at this point
Is the wing hanging off on the right side past the trunk? or does the picture just make it look like that? Not trying to shit on you, but I just was hoping you didnt mount it even. It looks beautiful man keep it up!
KravingAKouki is offline
Old 03-01-2013, 05:25 PM   #142
Extreme Dimensions
Wrinkled valve cover = PURE SEX!
- Chris Gary
Old 03-02-2013, 12:30 AM   #143
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Very extensive should be a beast
rawgarage is offline
Old 03-02-2013, 10:40 AM   #144
CleanAndLegit
Trader Rating: (55)
it's just the picture I measured it over and over aha.
thanks man!
Yes! looks awesome in person I'll post pics with it in the engine bay.
Thank you! should be!
Old 03-02-2013, 11:21 AM   #145
Pelukas91
Pelukas91 is an unknown quantity at this point
s13
Dude this story is inspiring as shit...im trying to do the same thing
and i live out here in rialto and im only 21 inpatient trying to find a
coupe and cant to build it from the ground up...sick ass coupe you have
man love it...
Pelukas91 is offline
Old 03-10-2013, 01:47 AM   #146
alexisthemovie
alexisthemovie's Avatar
alexisthemovie is an unknown quantity at this point
Send a message via AIM to alexisthemovie
I love it, did you slot your coilovers for more camber, or that purely from extending the LCA's?
My Build
http://wheelflip.com
alexisthemovie is offline
Old 03-10-2013, 04:07 AM   #147
SaNTi
SaNTi's Avatar
This.
Also did you get your S13 FLCA extended or S14? And by how much?
Progress looks awesome. Can't wait to see it all completed.
SaNTi is offline
Old 03-10-2013, 09:00 PM   #148
CleanAndLegit
Trader Rating: (55)
I did slot them but didn't need to do much, still havent gotten around to tightening everything up so it might be a little more or less to what you see in pics either way I can still slot it a bit more.
Originally Posted by SaNTi View Post
This.
s13 flca and 27mm shouldve done 35mm but ehh, and thanks man 2 more weeks and itll be painted.
Old 03-10-2013, 09:20 PM   #149
energy0uth
energy0uth is an unknown quantity at this point
wrinkle wrinkle. thats awesome.
energy0uth is offline
Old 03-10-2013, 09:40 PM   #150
ray_dizzle33
ray_dizzle33's Avatar
ray_dizzle33 is an unknown quantity at this point
Where did you get your valve cover done at? Want to go with a hybrid myself.
RIP Inland180
ray_dizzle33 is offline
Closed Thread
s13, silvia
