08-15-2008, 11:30 PM | #1 |
spedo el failo
my friends car is on like a speedo tripp right
its like this vroooomm bummmmmm like it hits limiter but thats not the issue the speedo will go on random hay wires like its retarded it will stay at the speed then fall then come back and fall again and when this happens his method of getting it back is to stab the brakes and it works and even if he stops for a good ten to fifteen mins everything is hooked up and good to go just have no clue why it is doing this any help would be appreciated |
08-16-2008, 02:16 PM | #2 |
Thats just a simple short in the wiring you have. Check wires to the speed sensor as well as wires from the ECU... And learn to use periods man its very difficult to read what you wrote..
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
08-17-2008, 04:16 PM | #4 |
My speedo does the same thing. I baught a speed sensor at Autozone for around $72 yesterday. I'm gonna check the connections first and if that doesn't work I'm gonna put in that speed sensor. I'll let you know if that fixes the speedo.
08-17-2008, 06:31 PM | #5 |
mine is doing the same thing... and i found out that my speedo pinion is worn out.. so, at some point the pinion cant get contact wit the trans.. so, i wont register... so you might want to check you pinion too
08-22-2008, 03:06 AM | #6 | ||
Now I'm gonna try to use a different guage cluster to see if that fixes my spedo problem.
