Clutch won't engage
I'm having issue with my clutch. I recently upgrade to a stage 2 bit now my clutch won't engage. I have bleed it a few time and still nothing . I have removed the damper box and ran the clutch li e straight to the slave cylinder and nothing. I would appreciate any suggestion. Thanks
![]() Join Date: Jun 2005
Can you hear the release bearing when you push the clutch in?
Fork or Pivot may not be engaged properly etc so when you do push the clutch pedal in, it is not pushing the release bearing into the pressure plate to release the clutch. Otherwise, as Kyral mentioned. Slave cylinder... Because if you are able to bleed it properly the MC should be fine.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
Yes the piston is moving in and out I replace both master cyclinder and slave. I'm not sure I will check tomorrow. But if is not making noise what does the mean. Will i have to replace the the bearing?
![]() Join Date: Mar 2012
So is your clutch not engaging, or not DISengaging? A clutch should always be engaged, even if your hydraulic clutch system doesn't work at all. So bleeding will never help it engage. Did you mount the clutch disc upside down?
@dedirkjan |
![]() Join Date: Jun 2003
Trader Rating: (129)
with the engine OFF, can you shift through the gears?
Clutch Lock out. Everything may be moving but the clutch disc is not separating from the flywheel. If you can put the car in gear when the engine off but not when its running I can almost guarantee thats the problem.
I had the same issue with my R154 not long ago and the clutch disc had seized against the flyheel. Pedal was fine, slave cylinder was fine, when I looked at the clutch through the inspection hole everything appeared to be fine.
NO HANDS IN PANTS!! |
#9 | |
The clutch is not engaging when the car is on. I don't think I mounted the clutch upside down, bu5 I could be wrong |
#10 | |
I can enter the gears when the car is off no problems but when I turn it on and try to go into first it won't let The clutch p3dal has no pressure once I turn the car on |
![]() Join Date: Jan 2008
The clutch pedal pressure has nothing to do at all with the engine running or not running.
However, the fact that you say that it does indicates a major mechanical issue. Sounds like the best approach is to drop the transmission and take a look. |
So did you end up dropping your granny? Did she manage to get back up on her own?
@dedirkjan |
