Hi there I have a question that may get me flamed but w/e. I have searched and since I couldn't get the answers I wanted I'm asking for help now. I have a zenki that I got kouki headlights for after I hit a deer. I have HIDs wired up already and as some of you already know where this is going my low beams shut off when I turn on my high beams as proof I've done my research I found this
So get a 30amp 5 pin relay. (repeat for each side) Pin 30 goes to the low beam projector Pin 85 goes to the high beam power Pin 87a goes to the high beam power Pin 87 goes to the low beam power Pin 86 to ground Other thing to consider is that the load on the high beam wiring may be too much to run both sets of lights. in that case connect pin 87a to the battery (important use a fuse). My problem is I've never used relays and I don't know if I'm supposed to cut anything If someone could please guide me in the right direction it would be greatly appreciated and pictures would be most helpful if you've already done it that way it would give me visual aid and make my life easier |
This is interesting. I am actually in a similar situation but cannot find answers. I have a Zenki, and a zenki harness that is snipped at the front accessory area. I have the front cut of a kouki harness and need to merge them together..Headlights, turn signals, horns, ect..
Are you using a kouki harness up front also? As for your relay addition, I did read in multiple areas that a relay has to be added for them to function correctly, but no one explained the pin out. Where are your pin outs coming from? The junction under the dash of the zenki? |
Here maybe this can help you a bit though..This will also help me somewhat. You'll need two 5 pin 30 amp relays. One for each side. The pin numbers should be listed on the top of the relay. See the photo below, but don't follow the wiring on that photo since you're doing headlights.
#/f/showthread.php?t=442921 Pin 30 goes to the low beam projector Pin 85 goes to the high beam power Pin 87a goes to the low beam power Pin 87 goes to the high beam power Pin 86 to ground ![]() Relays http://www.amazon.com/Relay-Harness-...ds=30amp+relay |
Before you start hacking away at your wires I was talking to a buddy of mine who is a mechanic who thinks that what actually needs to be done is replace the actual relays in the car and pin them out as mentioned above. Perhaps I've been going about this wrong the whole time il have to bust out the fsm to locate everything
#16 | |
Yeah my wiring actually was already all cut in half. I just merged a USDM fuse box harness with a JDM Kouki Light/horn harness. All my stuff seems to function as the FSM states. I am not running HIDs though. If I planned to I would just run HID's on the lows and buy nicer high beam bulbs instead since HID's do not reach their maximum brightness immediately. Per the FSM the lows are suppose to cancel when the highs are turned on. |
