12-10-2010, 12:32 PM | #1 |
no dash lights
ok so none of my lights come on the gauge cluster or lights for heat controls (light for clock is on when headlights aren't on but when i turn headlights on that goes out too). I checked online already and they said if your bake lights aren't working then prob wiring from brake lights is touching ground but my brake lights work so not sure what it is. also my airbag light is flashing
12-13-2010, 08:40 AM | #3 |
well if it worked before and all of a sudden didnt i would check all the main fuses in the passenger compartment (the 30-100a that you can see through the little plastic) if its on of those just go to a junkyard and get a couple they are 11cents each where i got mine.
12-14-2010, 07:55 AM | #4 | |
