#573 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
What are you dudes using to reseal the lenses to the housings after you open headlights up? I keep putting off putting my clear lenses on because I don't know what to use to seal them.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#574 | |
#575 |
Here's a little update on the MDX retrofit if anyone is still interested.. The projectors do fit in the housing easily. The heatshink is so large that it will require some material to be removed from the radiator support. We have a long way to go since we need to create a new housing to fit everything..
![]() I'm not sure how I feel about the ~1/2" gaps on either side.. It will be shrouded but still.. |
#576 |
just an idea for the gap on each side, why don't you push it against the edge and have the inner portion be an additional light source for DRL or something?
I want to see the back side of this thing!
#579 |
![]() Join Date: Apr 2006
i dont mean to rain on anyone's parade here
but just in case you didnt notice, the size of those led headlights exceeds the size of the factory headlight assembly. just saying. |
#580 |
Even if they did "fit" inside the housings the angle is all wrong. In order for the left-right to be correct there will need to be like a 4-5" gap between the outside LED projector lens and the inside of the kouki front lens and the inside most LED projector would have to be basically touching the inside of the kouki front lens...
'98 240sx 5spd |
#582 | ||
![]() Join Date: Jun 2004
Trader Rating: (73)
#583 |
![]() Join Date: Oct 2007
Trader Rating: (53)
Does anyone know the bulb type for the fan switch on the S14 HVAC unit? i know i can use the Neo 3's in the other 3 spots but i cant find anything saying what type of bulb is used for the fan switch.
#588 |
For i got did these a few weeks ago. me and a friend learned how to do these together and made it a little project. was a pain in the ass highly time consuming lol but in all worth it. i also did the same little row up on the other light as well. the led blinkers are really bright. i think i need to dim them down a little more.
IMG_8075 by Aallmighty, on Flickr IMG_8072 by Aallmighty, on Flickr
Some black guy who lurks zilvia. |
#592 |
I just got done with another TRS Morimoto Mini H1 retrofit into a S14 Zenki headlight yesterday. This time using the JDM S14 lights.
Heatguned the lights apart to reveal the insides. ![]() And we have some problems... ![]() Design of the JDM S14 headlights are a wee bit different than of the USDM ones..I was looking forward to just fitting them in and being done with them in few hours. NOP! These two that's pointed at with the screw driver had to be gone. this took few hours on the first one, and just breezed through on the second one. ![]() ![]() I was never good at trimming the shroud...oh wells. ![]() ![]() ![]() Got to finish both of them in one sitting. over all with small distractions here and there, took 7 hours to finish. ![]() I haven't put the clear covers on it yet. Will update when it goes on the car along with some cut off shots.
#594 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Glad to see people car about lighting. Start playing on HIDPLANET and you will be amazed. My most current retro......obviously not a 240 but I have not owned one for like 3 years. This is my current DD as I got rid of my 2013 corolla to get something cooler
RX350, green passive demon eye and MCR shrouds. Headlights are using OEM Matsushita ballast and TRS XB35 5500k bulbs, car also has retrofitted fog lights with ES300 yellow fogs with a DDM 3000k HID kit. So nice to be able to see at night. The old beat lights with a H4 halogen bulb sucked! 20150117_163834 by malachilikescars, on Flickr 20150126_120456 by malachilikescars, on Flickr 20150126_120510 by malachilikescars, on FlickrI put the amber back in the housings today, much better 20150204_154057 by malachilikescars, on Flickr 20150204_162629 by malachilikescars, on Flickr |
#599 |
#600 |
