Nissan 240sx 1989-1994 S13 Manual Transmission Removal and Installation
Click on the link to see the complete article with images check it out here: Nissan 240sx Manual Transmission Removal and Installation. Garage411.com
LUBRICATION SERVICE INTERVALS Inspect tranny fluid level every 15,000 miles or 12 months. If under severe usage, change fluid every 30,000 miles or 24 months. CHECKING TRANNY FLUID LEVEL Fill plug is located on side of transmission case. Lubricant level should be to bottom of fill hole. Add fluid if necessary. RECOMMENDED FLUID Use Hypoid SAE 75W-90 (API GL-4) gear oil. TRANSMISSION REFILL CAPACITIES
Manual Transmission Removal and Installation Removal 1. Disconnect battery terminals and accelerator linkage. Place shift lever in Neutral position. Remove shift lever boot, snap ring or nut, shift lever pin and shift lever. Raise and support vehicle. 2. Disconnect exhaust pipe from manifold. Remove bolts mounting exhaust pipe bracket to extension housing or rear engine crossmember (if necessary). Remove exhaust pipe insulator. Disconnect all electrical connectors from transmission. Disconnect speedometer cable. 3. Mark drive shafts and companion flanges for installation reference. Separate center support bearing from crossmember. Remove drive shaft. Plug rear of transmission to prevent fluid loss. Remove slave cylinder. Support engine and transmission using jacks. Loosen rear engine mount attaching bolt. 4. Remove rear engine mount bracket. Support transmission. Remove starter and engine-to-transmission bolts. Slide transmission rearward and remove transmission. Installation 1. Lightly lubricate clutch disc splines with molybdenum grease. Slide clutch disc onto mainshaft splines. Remove clutch disc. Wipe off excess grease. Install clutch assembly onto guide dowels. Use clutch aligning tool to center disc and pressure plate. 2. Using a crisscross pattern, tighten bolts evenly one turn at a time to specification. To complete installation, reverse removal procedure. Click on the link to see the complete article with images check it out here: Nissan 240sx Manual Transmission Removal and Installation. Garage411.com |
| 240sx manual transmission, 240sx mt, garage411.com, s13 manual transmission, s13 mt |
