#3 | |
![]() Join Date: Dec 2006
Head Gasket???? Good luck on that set up, You'll blow the H/G as that turbo hits full spool Not try to be a dick, but you really need to Search. This shits been covered countless times
Im a noob on sr and I woudn't come up with this list if I did't search on 3 240 forums. No not at all, i see it as a good suggestion. Head gasket and studs it is as soon as i get the money and guts to mess with sr20s..
![]() Join Date: Sep 2005
And if you wanted Pros and Cons... Pro - Peakboost makes AWESOME products and warranty them accordingly. They also have excellent customer service and will even help you over the phone. Cons - Mad $$$ for what you get. This as a kit is something that an individual could peice together for considerably less. Personally I don't care for T3/T04 turbos. |
Man w/ CTSV & a Car Seat
If 340-370 is your goal...why dont you just save the dough, and get a GT2871R .86 trim? You can hit those numbers with the 740cc, PFC and HKS Actuator. You get to reuse most of the stuff you already have.
Some peeps made that w/ the .64 housing, which will spool up quicker than the .86 housing version.
#10 | |
#12 | |
With 740cc, why the fuck not get the bigger trim?!?! ![]() |
Because you'd have to sacrifice some mid range punch by giving up some spool.
But if you've got a 8k+ rpm motor, then 850cc's, GReddy intake mani, and 270 or 272 cams + 2871R .86 A/R would pretty much melt faces. |
#14 | |
![]() Join Date: Jan 2008
incorrect, i have know of a few STOCK SR20dets with just headgasket and headstuds put down 460whp on C16 with a GT30 and another with a T04E put down 380whp on pump gas. min ewill be out later this year stock internals putting down similar #'s on a T04e |
#15 | |
ewww fuck a "T" turbo.
GT2871R for that power range it will spool 10 times faster. get a ported compressor housing and an external wastegate vband turbine housing.
