![]() Join Date: Jul 2013
walbro gss341..hmmm
Just curious what you guys do about the bottom mounting insulator when using a walbro FP.
I purchased and installed a GSS341 and i did my research just to confirm my pump was legit and not a fake. Anyway that is all well and good, my pump is legit. One problem i ran into was the bottom insulator rubber piece does not fit the walbro very well and I ended up cutting a small section of it out and made it fit the best I could but I am not happy with it. Is there a certain insulator that is supposed to be used or are we stuck using the stock one and modifying it. Notes: 95 s14 gss341 walbro 255 97 01 prelude sock
95 S14 se RB25DET 348whp
![]() Join Date: Dec 2004
Trader Rating: (58)
It doesn't need to be a 100% fit, but it is super tight for sure. You'll be fine.
I trimmed the bottom mounting pad and I ummm
Zip tied the pump to the bracket.... I didn't know what else to do without having a better fitting insulator. O_o
