![]() Join Date: Jun 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
hey guys,
im parting out a 1997 240sx SE. everything will be listed and pictured below All parts are located in Westminster California (92683) I will ship at buyer expense plus the 3% paypal fee. email/paypal: [email protected] Thanks! adam k All Pricing is assuming that you are PICKING UP. A/C lines: SOLD OEM suspension with KYB GR-2 fronts: SOLD!!!! OEM Tie Rods: $30 OEM Tension Rods: $15 OEM engine mounts: SOLD!!! OEM SE front Sway Bar: $25 Front Lower Control Arms: SOLD A/C condenser: $35 Power Steering Rack: $75 Front Cross Member: $30 Hood Hinges: $15 each Ebrake Handle: $20 Rear Subframe: SOLD!!! Rear OEM Sway Bar: $25 Driver Side Silver Moss door w/ window: SOLD! Very clean Headliner: SOLD! SE Front Seats: SOLD Dash Bar support: $30 Cluster Trim: SOLD! Steering Column plastic: $10 Turn Signal switches: $15 Windshield Wiper switches: SOLD!!! B and C pillar interior plastic: $10 each Rear SE seats: SOLD A pillar interior plastic: $10 each Speaker Deck: SOLD Climate control trim with switches: SOLD! Heater Core: SOLD Gas Tank Door: $10 Driver Side Kouki fender (has some damage. see pictures): SOLD Steering Column: SOLD!!!!! Key Lock and Ignition set. Includes L&R Door locks, Ignition, and trunk lock.: SOLD!!! KA fuel rail with injectors: $25 Power steering lines with Reservoir: SOLD! KA clutch: SOLD!! OEM Shifter: $15
not anti-drift, just pro-grip Last edited by Knapik; 01-17-2010 at 11:19 AM.. |
Trader Rating: (36)
Rear Seat Belts: $35
I have the front pair as well. i just dont have a picture right now: $35 Ebrake Lines: $15 KA Alternator: $40 Rear Lower Control Arms: $55 Power Mirror Switch: SOLD Center Console (inside console was trimmed to run some wiring. See pictures for "damage") : $30 Front Map Light: $20 Rear Map Light: $20 Door Sill Plastics: SOLD!! Rear View Mirror: $15 Hood Cable: $25 SHIT TON of audio wiring: $30
not anti-drift, just pro-grip Last edited by Knapik; 12-17-2009 at 08:24 PM.. |
![]() Join Date: Dec 2008
interested in the seats, pm sent, i can pick up today
http://silaudrey.blogspot.com/ |
![]() Join Date: Oct 2008
interested in
FLCAs coin holders out of center console driver side window motor/regulator (not the whole door) package price shipped to 32615? thanks!!! |
#16 | |||||
Trader Rating: (36)
sorry i dont. the car was in a mild front end collision. so a lot of little parts in the front are broken.
i know...i know ![]() pmed Quote:
_________________________________ all parts are first come first serve. if official arrangements are made i will hold true to them, but parts will not be updated as "sold" on the thread until you have the parts and i have the money. thank you adam k
not anti-drift, just pro-grip |
#20 |
![]() Join Date: Mar 2009
I need steering wheel coil horn thingy that is right under the steering wheel once you remove it. The coil type of plastic piece that helps retain for use of aftermarket steering wheel to use the horn.
I really do not know what it is called or how else to explain it... I need it with the wires uncut. All I know is that its black square piece RIGHT UNDER THE steering wheel once it is pulled off with a bunch of round coils inside of it. I'll buy it ASAP please let me know ~ Thanks! Located in Los Angeles
Super-Made Instant Gentleman Zenki S14 VIP itzjOw3.com Phen Club |
#21 | |
![]() Join Date: Jan 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 15 reviews
guessing the tension rod bushings are bad?
-Lloyd ![]() Quote:
#26 | ||||||
Trader Rating: (36)
i dont want to separate the key/lock set for obvious reasons so it will be sold as a complete set. -$55 Quote:
![]() they are in ok shape. pmed you Quote:
pmed you sir Quote:
maybe someone can help me out on this one? any one know if s14 booster and master cylinder will swap onto a s13?
#30 | |||
Trader Rating: (36)
thanks! i do my best haha pmed you. Quote:
______________________________________ update: Trunk carpet, front LCA's, front and rear SE seats no longer pending sale and are back up for grabs. im sorry about the inconvenience. Thanks! adam k ![]()
