![]() Join Date: Dec 2011
OK so im extending my flca on my s14 25mm. was told i need longer tie rods. can i use my stock or what else can i use . im in a hurry so i dont have time to order rods online. so is there any nissan i can use rods off of that i can order from autozone or oriely? thanks
Pretty sure there are lengths listed in the roll center thread. Stock s14 inners/outers will be too short.
Infiniti I30 inners will probably work for you... Maxima outer tie rods are about 1" longer and will also work. |
