Old 07-01-2007, 05:33 PM   #241
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
car: 1993 Silvia S14
trim: K's Club
color: black
engine build plan: SR20 that revs to 10k
current power rating: N/A
Engine
* HKS T04S
* Trust Type R wastegate
* Tomei 270 degree duration 12.5mm lift cams
* Tomei cam gears
* Tomei solid lifters
* Tomei double valve springs
* Rocker arm stoppers (probably Tomei)
* SR20DE throttle body
* Intake has been ported
* Trust 6qt baffled oil pan
* Delphi 3 core aluminum radiator
* Unkown electric fans
* Oil pickup has been milled out for better pickup
* Sard FPR
* Sard 850cc injectors
* GTR fuel pump
* Trust FMIC
* 1.2mm Greddy metal headgasket
* ARP rod and head bolts
* Greddy Type R BOV
* MoTeC M400 ECU
* Buddy Club Spec II w/ test pipe
* Custom turboback downpipe
Powertrain
* OS Giken twin plate clutch
* CA transmission
* Kaaz 2 way diff with 4.3 final drive
* Stillway 0-400m shifter
Suspension, wheels, tires and brakes
* 33 GTR wheels
* 33 GTR Brembo calipers (front)
* 245/50/17 Falken Azenis RT615
* Endless CCX Carbon pads (front)
* Apex'i 2 peice 310mm x 28mm slotted rotors (front)
* Swage stainless braided brake lines (front)
* Cusco brake master cylinder brace
* Cusco Comp S coilovers
* Stark brand tension control rods
* Greddy front strut tower bar
* Unkown, really thick, pink swaybars
Interior
* Rear is gutted
* Recaro SR111 (passenger)
* Recaro SPG (driver)
* Super bitchin steering wheel
* Flava Flav edition Blitz boost guage
* Fuzzy dash
* PTCS D200 dash logger
* Broadway wideangle mirror (must have in Japan)
* Aluminum 8 point cage
Exterior
* Airduct
* Ram air headlamp (for "track" days)
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 07-01-2007, 06:02 PM   #242
VAs13
VAs13's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
car: 1992 240sx
trim: SE
color: burnt orange
body style: hatchback
engine build plan: 350-400whp
current power rating: 220hp @ 12psi
modifications:
Redtop SR20DET
GReddy M-Spec FMIC
Koyo Rad
Apexi Dual N1 exh
3" downpipe custom
apexi safc II
exedy clutch
S14 seats
plan modifications:
Kouki tail lights
180sx sideskirts/rear valances
xenon lip
upgrade internals
bigger turbo
Old 07-01-2007, 07:31 PM   #243
Wabash9000
Wabash9000 has a little shameless behavior in the past
car: 1995 240SX
trim: Base
color: Some sort of gold, some tag from a dealer says beige
body style: coupe
engine build plan: Stock n/a maybe intake and exsuast
current power rating: stock
modifications:
Pannisonic CQ-C7301U head unit
Deleted factory amplifiers
Rockford Forsgate P163C Door speakers
Rockford Forsgate P163C Rear deck speakers
Rockford Forsgate 200hz passive base blockers
Rockford Forsgate 8 Gauge Amplifier Wire Kit
Rockford Forsgate 325.1 Amplifier
Rockford Forsgate P210S1 Subwoofer
Non-brand name ebay .28 cu ft subwoofer box
SPL parts rear subframe bushing collars
Planed Modifications:
S13 SE 7 spoke 15 inch wheels to get rid of gay hub caps.
Ebay brand intake
2.25 inch coustom made cat back exsaust
Magnaflow 14833 Street muffler
Wabash9000 is offline   Reply With Quote
Old 07-02-2007, 02:59 AM   #244
Tearlessj
Tearlessj's Avatar
car: 1993 240SX
trim: SE
color: Red
body style: Hatch
engine build plan: Single Turbo around 450hp on stock block.
current power rating: None.
modifications:
18" Work Equips in weak offsets
Painted engine bay
Scion TC Pioneer head unit
JDM LED shift knob
NRG short hub and QR
Momo wheel with Hello Kitty horn
Hello kitty shift boot
Re-wrapped door panels and glove box
Hk sticker.lol
Replaced rear quater panel?
Planed Modifications: (Hopefully by Spring Break)
2JZ swap with parts from Tech2Motorsports and 2JZSWAP.com
Supporting mods for 2JZ (Bov. FMIC. Downpipe)
3" Exhaust with no muffler as of rite now.
Xs Power Single Turbo Manifold
Swantko Special Turbo produced by Sound Performance
S-AFC II
Stock Fuel for now.
Welded diff
Replace all bushings
One day, AEM EMS
By Fall 2008
Stance GR+ Pro Coilovers
Tie rods, Camber arms, braces Ect.
Widebody Fenders
Some Baller wheels
When ever
300zx Brakes with SS lines
Cheap Replica Kit
Kouki tails
House of color garage paint job
Spot welded frame
8 point cage
Memoryfab seat
Lexus LS passenger seat
Rhino Liner trunk
Some kind of Leather soft rear seats
New carpet
10" Fi Q sub with 1000watt Hifonic 5 way
CDT components front, no Rear fill set up
Carputer with 8 in screen
Greddy Profec
STRI gauges
Fake Suede dash, door panels, Glove box and headliner
5 panel mirror
Thats about most of it.
Tearlessj is offline   Reply With Quote
Old 07-02-2007, 08:15 AM   #245
xDATx
xDATx's Avatar
xDATx can only hope to improve
car: 1990 240sx mutt
trim: base model
color: ?
body style: coupe
current power rating: fun to drive / gets me to work
modifications:
Stock Redtop SR20DET
Custom Bar and Plate IC used, used Piping HKS/Greddy
Gizmo intake manifold gasket
Amazon Hose Co. T-Bolt clams and couplings
Koyo Rad , samco hoses, Permacool Fan
Apexi GT Spec used
Greddy downpipe
Joe P MBC
apexi safc used
N60MAFS used, ebay intake pipe
Tampa Bay Clutch stage 1
S14 seat -
M's shift knob - used
KA tranny
HKS SSQ BOV
ER hotpipe
100% K&N air filter
Ebay Strut tower braces
DIY engine ground
miata battery
ST swaybars front and rear
MR Coilovers
K's front end
K's front brakes
Poject Nissan resonated test pipe
HKS turbo Timer type I
Ebay RUCAs
PDM-Racing FLCAs
'91 SE wheels Khumo Ecstas 225 50R15
Frank Castle security system
Battle Version adjustable Tension Rods
plan modifications:
Paint and Body work (no hip-hop body kit)
xDATx is offline   Reply With Quote
Old 07-02-2007, 08:03 PM   #246
turbobrick
turbobrick's Avatar
turbobrick is on a distinguished road
car: 1990 240sx
trim: base, I think
color: used to be grey, mostly still is
body style: hatch
engine: S14 SR20DE
current power rating: stockish
modifications:
17x8 ssr gp-0 wheels
or 15x7 enkei 92 mesh
k-sport coilovers
intake make from left over 3 inch exhaust parts
electric radiator fans
turbobrick is offline   Reply With Quote
Old 07-02-2007, 09:10 PM   #247
conner
conner's Avatar
conner is an unknown quantity at this point
Car: 1992 240sx
Trim: Base
Color: Maroon?
Body Style: Hatch
Engine: Redtop Sr20
Engine Build Plan: 350-400rwhp
Current Power: 232rwhp at 14psi (stock mafs, injectors, etc...)
Modifications:
Apexi N1 EXV Coilovers
RS*R Polyurethane Bushings
RUCAS
Rear Toe arms
Strut Bars
Falken Hanabi F:17x7.5 +35 R:17x9 +20
Tires: F:Falken Azenis ST115 R:Federal SS-595
Redtop SR
RPS MaxStreet Clutch
ACT Prolite Flywheel
Nismo Solid Shifter
MR Exhaust Manifold
MR Turbo Elbow
Blitz Realize Exhaust w/3in cutout
HKS SSQV Bov
Greddy FMIC
N62 MAFS
SAFC II
CS Oil Catch Can
Intake
Helios HIDs
JDM Front Turn Signals
180sx Rear Center Taillight
35% Window Tint
Z32 Shift Knob
Nardi Steering Wheel
POS Stereo
POS Pioneer Speakers
Planned Modifications:
Tanabe Sway Bars
Battle Version T/C Rods
Tein In/Out Tie Rods
Rear Traction Arms
GT2871R .86
Nismo 740cc Injectors
CS Turbo Lines
Enthalpy Rom Tune
Then after all that is done and get bored with that powerband:
BC Cams, Springs Retainers
Apexi Head Gasket
ARP Headstuds
Then a new Tune.
Conner
SYDE WYZ
conner is offline   Reply With Quote
Old 07-02-2007, 11:21 PM   #248
jilo
jilo's Avatar
jilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of light
yea fuck that, this is a dumb idea. im retarded.
"just throw in like 8 packs of BBs and do a burnout.
DIY shot peen, done and done."
jilo is offline   Reply With Quote
Old 07-02-2007, 11:41 PM   #249
UfoZ8myCow
UfoZ8myCow's Avatar
UfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond reputeUfoZ8myCow has a reputation beyond repute
Seriously? You guys are still posting in this thread with all these stolen 240 threads? Why not just post up your address and leave your car keys in the ignition tonight?
UfoZ8myCow is offline   Reply With Quote
Old 07-03-2007, 03:03 AM   #250
Koopa Troopa
LOL, if someone were to fly over here and steal a car on an island that's only 68 miles long and not get caught then they deserve to have it...
Old 08-02-2007, 10:52 AM   #251
Sileighty_85
Sileighty_85's Avatar
Ha ha ha I hear that.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-07-2007, 02:26 PM   #252
CusCo_S14
CusCo_S14's Avatar
CusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud of
Car: 95 240sx
Trim: Se w sunroof
Color: Aspen White
Body: Style Coupe
Engine: Build: N/A KA
Current Power: Stock
Mods
Cusco Zero2 coilovers
Cusco front strut bar
Cusco rear strut bar
Cusco front sway bar
Cusco rear sway bar
Cusco lower radius bar
Cusco front tension rods
Cusco ruca
Cusco cooling panel
Random Technology
HKS Hi-Power cat back
Accel 8.5mm plug wires
Hyper ground system
JDM power folding mirrors(not working)
B&M short throw shifter
Nismo titanium shift knob
Eclipse 6.5"touch screen indash
Focal 6.5" components
Focal 6.5"rear mids
MTX 12"800w sub
MTX 1200w sub amp
Alpine 400w component amp
Future mods
ACT street clutch
Fidanza aluminum flywheel
Z32 front 26mm calipers
slotted front rotors
slotted rear rotors
steel braided clutch line
steel braided brake lines
Work XD9 18x9 18x10
replace bushings
CusCo_S14 is offline   Reply With Quote
Old 08-07-2007, 02:42 PM   #253
t . b o z
t . b o z's Avatar
t . b o z will become famous soon enought . b o z will become famous soon enought . b o z will become famous soon enough
Car : 90 240sx
Trim : Base
Color : Cherry metallic/pearl whatever you call it.
Body Style : Coupe
Engine : KA24DE
Power : STOCK AS A ROCK!!!
Under the hood :
KA24De
NGK plug wires
Apex'i air filter
Suspension/brakes:
Nismo shocks
RS*R springs in rear
HKS springs up front
Tein inner/outer tie rods
Peak Performance tension arms(not installed)
Stock rotors
Hawk Pads
Drivetrain :
ATS Deftforce 2-way LSD
Exedy Stg. 1 clutch/flywheel
Megan(dont buy it) shortshifter.
Exterior:
Sportmax 001 15x8 0 offset (black)
Hella H4 conversion
Interior:
Kazama shift knob
Nardi Classic 350mm wheel
Kazama drift knob
Kenwood cd player
Buddy Club bucket(on the way)
Buddy Club seat rails (not on car)
I can't wait to get coilovers and some more suspension stuff!! then, comes boooooost. and maybe the sexy style front and sides
t . b o z is offline   Reply With Quote
Old 08-07-2007, 04:23 PM   #254
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
Car : 89 240sx
Trim : Base
Color : Super Black
Body Style : Hatch
Engine : S14 SR20DET
Under the hood :
Rebuilt Zenki S14 SR20DET
Rebuilt Head and Block, greddy bottom end
S15 harness and ecu (mines)
Tomei Headgasket,
S15 Turbo, w/ stainless steel manifold, turbo elbow, 3" downpipe.
Walbro 255
Apex-N1 single exhaust
Greddy Front mount
Zilvia.net Intake pipe w/ z32
Samco Hoses
Suspension/brakes/drivetrain:
Hks hipermax coilovers
Tomei Technial 2Way LSD
Battle Version Rear upper control arms
z32 front brake calipers, slotted drilled rotors, ss lines, project mu pads,
S14 5 Lug conversion, S14 FLCA's and S14 rear hubs
Peak preformance Studs
Cusco strut bars
Exterior:
replica URAS Aero kit held on by jdm daiso zipties haha
Kouki tail's w/ rps13 garnish
volk c ultra 18x9.5 -3 and 18x9.5 +14
30mm front widebody fenders
Interior:
Momo race 350mm steering wheel
Jdm pink shift knob
S14 Seats
I'm forgetting stuff i'm sure. etc needs more interior work, more power, and better wheels. Selling mine soon and getting white cr kai's.
sblack13 is offline   Reply With Quote
Old 08-07-2007, 04:33 PM   #255
shadysi
shadysi's Avatar
shadysi is just really niceshadysi is just really niceshadysi is just really niceshadysi is just really niceshadysi is just really niceshadysi is just really niceshadysi is just really niceshadysi is just really nice
92 green hatch base
stock tan, brown and tweed interior
ka24
no cat
kaaz 2-way
then end... just got it a month ago.. saving up for other stuff, its my drift project
shadysi is offline   Reply With Quote
Old 08-07-2007, 04:34 PM   #256
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
car: 1990 240sx
trim: SE
color: Black
body style: Fastback
current power rating: 260+ (in the past) now: 15. (fried pistons FTW)
modifications:
Redtop Sr20det. @ 16psi (OVERBOOST FOR THE WIN!!!)
3" XS power Dumppipe
3" Megan racing downpipe
3" Apexi N1 single exhaust
K&N air filter set up
Walbro 255LPH fuel pump
Tanabe Sustec GF210 springs
Koni 3-way Adj shocks
Equis A/F gauge
Equis boost gauge
Equis Voltage meter
VLSD
plan modifications:
GT3582r
AEM Uego controller
Trust turbo timer
Trust boost controller
MSD DIS-4
splitfire DIS004 coil packs
godspeed intercooler
peakboost topmount manifold
tial wastegate
810cc Deatschwerks injectors
A full T-sleeving of the block
87mm 8.1:1 compression pistons... probably CP.
Pauter Titanium Rods.
Jun 270 dur. solid lifter camshaft setup
JWT bronze valve guides
JWT stem seals
BC springs
BC retainers
port/polished head (courtesy of me).
HKS 1.2mm head gasket
Power Enterprises "black metal" main and rod bearings
Meziere electric water pump (to get rid of that crappy stock water pump)
Greddy oil cooler kit
Greddy intake manifold
Greddy oil pan
Koyo radiator with the necessary electric fans
nismo/sard/*insert reputable company here* FPR.
*insert BOV type here* (im not picky about what "sound I have")
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 08-19-2007, 09:36 PM   #257
Z33dori
Z33dori's Avatar
car: 91 240sx
trim: se super hicas
color: burgandy/maroon
build engine: SR20
current hp: 150 ka
Modifications:
Trust PEII
free mod air box
brembo blank rotors
nismo clutch
Ksport coilovers
Plan modifications:
sr20det.......cont l8tr have thought out the rest.
Old 08-20-2007, 04:53 AM   #258
amplifi3d
amplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-knownamplifi3d is making his/her stupidity well-known
Apexi Evx? Coilovers
yanack steering rack bushings
tein tie rods
jic tension rods
Ultra Racing Front 4 Point Bar
Uras Power Brace Spacers
Battle Version front lower control arms
Suspension Techniques front sway bar
Suspension Techniques Sway Bar Bushings
Aluminum Sub Frame Spacers
Battle Version Rear Lower Control Arms
Battle Version RUCA
Battle Version Toe Rod
Battle Version Traction Rod
Largus Rear Sway Bar
Ebay Diff Bar
Ultra Racing Rear Sway Bar
Cusco Front Sway Bar
5 Lug
300zx Brakes
amplifi3d is offline   Reply With Quote
Old 08-20-2007, 10:43 AM   #259
UfoZ8myCow
UfoZ8myCow's Avatar
Ive said it before and Ill say it again...
Actually, Ill post up the mod lists for one section of my car:
Security:
Alarm system with power door locks
Quick release steering
Glock 21C with five 13 round magazines (.45 ACP)
A pissed off German Shepherd that will chew your nuts off if he doesnt know you and you try to come into the yard.
Old 08-20-2007, 11:51 AM   #260
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
Car: 95 240sx
Trim: SE
Color: Stock Ultra Red
Body Style: Coupe
Engine Build: Turbo
Power Rating: N/A
Mods:
Enigne:
SR20DET engine swap
Hybrid Inter-cooler
Megan turbo elbow
Project Nissan test pipe
Project Nissan down pipe
Altmia electric fan
Griffin Alum Radiator
HKS BOV
Walbro fuel pump
Suspension
KYB Aga Stocks
RSR spring (unknown)
Future mods
All new suspension arms from Megan Racing (waiting in my room)
Boost controller
R33 GTR steering wheel (waiting in my room)
Step 1 cams from HKS, valve springs, and rocker arm stopper
Gauges : Boost, oil pressure, and water temp.
Fuel pump cut-off switch (hidden somewhere inside)
VLSD with 5 bolts axles (need to rebuild one of the axles)
chituntang is offline   Reply With Quote
Old 05-14-2008, 05:42 PM   #261
DriftSwift
DriftSwift's Avatar
DriftSwift will become famous soon enoughDriftSwift will become famous soon enoughDriftSwift will become famous soon enoughDriftSwift will become famous soon enoughDriftSwift will become famous soon enough
Car: 1995 S14 240sx
Trim: SE
Color: Pearl White
Body style: Coupe
Engine build plan: natural aspired
Current power rating: Stock plus Exhaust
What ever that is.
Modifications:
Aftermarket Airfilter.
Tokico D Spec Shocks on Eibach Pro Kit Springs
Custom 2.5 inch Dual exhaust
Lighting High Voltage Ground Kit
Xenon 8000k HID kit
Kouki Side Skirts
SE Front Lip
Interior:
No Brand Quick Release
Momo Steering Wheel
Sparco 4 Point Harness
Momo Shift Knob
Jensen 800 Watt AMP
10 inch Kicker Comp
Wheels:
5 Zigen FN01R-C 17x9
Yokohama 225/45/R17
Brigestone 225/45/ZR17
Plans:
Headers
Stage 1 Brian Crower Cams
Z32 Brakes Calipers and Rotors
Kouki Valences
Kouki Wing
Origin Roof Wing
Carbon Fiber Trunk.
Security:
Quick Release
2 Way Paging
Power lock Doors
1/2 Siberium Husky i cant say the other half
Guard Dog
No plans to go Turbo or SR or RB even though
it would be cool but in Cali i got pulled over twice
and they automatically asked if i can pop my hood.
So im good sounding loud without sacrificing the stock
look is good for me and my car. and looking cool is my
opinion
Team Outkast So Cal Division
Reppin since 1993
DriftSwift is offline   Reply With Quote
Old 07-11-2008, 11:48 AM   #262
sldbyuramg
sldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant future
I will be posting a build thread soon
car: 1990 240sx (automatic)
color: gray
body style: hatch
engine build plan: forced induction
current power rating: unkown atm
modifications:
RB20DET with 5spd of course
kragen air filter (k/n knock off)
dual electric fans 2500cfm flexlite
circuit sports coolant reservoir
FMIC
walboro fuel pump and 300zxtt fuel filter
hallman MBC
tanabe front and rear sway bar
KYB GR2 shocks with tanabe GF... lowering springs
megan tension rods
new rotors and pads
misc...sanded engine bay during swap and applied 3 coats of high temp satin black
painted valve covers to closely match body color.
painted control arms and various suspension and chassis components
STRI gauges
plan modifications:
quick release with lock and steering wheel (ordering next week)
LSD 1.5
5 lug and wheels/tires
S14 seats
gut interior
custom stealth chassis rigitity bars
injectors
turbo kit
intake manifold
new FMIC
suede dash and trim
overall goal:
to run a 12.5 or better 1/4 mile just once
then weekend TA or autocross
sldbyuramg is offline   Reply With Quote
Old 07-11-2008, 12:36 PM   #263
Avante
Avante's Avatar
Avante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfection
car: 1997 nissan 240sx se
color: ancient chinese secret
engine: sr20det
Mods:
300zx fuel filter
Security for my piece o' shit car:
Glock 31 .357
M4A1 Carbine 5.56
whoo!
come and TRY to take my fuel filter.
Avante is offline   Reply With Quote
Old 07-11-2008, 02:41 PM   #264
cgtdream
cgtdream's Avatar
cgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond repute
car: 1995 240sx
trim: Base Model
color: Purple - Magneta
body style: coupe
engine build plan: Blacktop SR20DET
current power rating: Unknown
modifications:
Tein Basic Coilovers
Tanabe Sway Bars
GReddy strut Tower Bar
Energy Suspension Bushings
Hawk brake pads
Stainless steel Brake lines
Walbro 255 Pump
Fluidyne radiator
Electric fans
Egay Intercooler Kit
Nismo FPR
Exedy Lightweight flywheel
Exedy Stage 2 clutch
Stainless steel clutch line
Nismo Master/slave cylinders
Cusco Engine Mounts
Solid type tranny mount
Megan Racing type 2 exhaust
Megan Racing exhaust manifold/turbo elbow/dumppipe
planed modifications:
GReddy type RS blow off valve
GReddy sm Integrate w/ gauges
GReddy Turbo Timer
Greddy Profec B boost controller
GreddyEmanage Ultimate
AEM Wideband UEgo sensor/gauge
Tein Tension Rods
Tein Inner/Outer Tie Rods
Tein PillowBall Upper Mounts
Megan Racing Short Shifter
Z32 MAf
S14 Kouiku Front End conversion
S14 car seats
Juicy slayin aint easy, but dammit somebody has to do it!!!
cgtdream is offline   Reply With Quote
Old 07-11-2008, 04:55 PM   #265
jbuckley
jbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of light
car : 240sx
motor: Ka24e Automatic
mods:
Shift knob
Drift knob
Pedal covers
Gutted interior
seat cover
Engine mods:
cone filter
Exterior: primer
other : i ripped out my radio because i didnt need it and i took my glovecompartment out , i only have one seat
jbuckley is offline   Reply With Quote
Old 07-11-2008, 05:00 PM   #266
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
Car: S13.
Color: dirty.
Motor: Yep, I've got one.
Mods:
-Some.
burnsauto is offline   Reply With Quote
Old 07-14-2008, 01:59 AM   #267
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
car: 1989 240sx (currently not running)
trim: SE
color: dark blue w/black hud
body style: hatch
engine build: turbo
current power rating: n/a
modifications:
s13 sr20det blacktop
HKS step 1 cams
Greddy fmic
Greddy rs bov
HKS acuator (stock turbo)
Greddy downpipe
Project Nissan solid motor mounts
Ebay 2" core radiator
Nismo thermostat
Custom 2.25 inch exhast
Circuit Sport elbow (on its way!!!)
Walbro fp
ACT clutch
Rides:
Tokico shocks
skunk 2 springs
two back spare tires
two front jackstands
Audio:
Some pioneers around (came with car)
Cheap kenwood tape player (came with car)
Future plans:
hks gt25 turbo
custom oil cooler
more suspension work
Sell for S2k or M3
bl3ujay07 is offline   Reply With Quote
Old 06-29-2009, 08:17 PM   #268
I LUV MY S13
I LUV MY S13's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
(bringing back a dead thread)
car: 1990 s13
trim: base
color: red
body style: hatch
engine build plan: rebuilt rb20det
mods:
suspension
tein super street coilovers
tein tension rods
brembo crossdrilled slotted rotors
exterior
pignose lip
fog lights
sideskirts
limo tint all around
interior
clean dash
s14 seats new carpet
custom shift boot
engine/drivetrain ka24e
injen intake
circuitsport overflow tank
exedy stage 1 clutch
fidanza flywheel
nismo short shifter
93 tranny
3 1/2" exhaust
future mods
wheels
paint job
tierods
power brace
rucas
diff
all i can think of ha
-Jorge
Old 07-09-2009, 03:50 PM   #269
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
car: 1995
trim: Base
color: Black
engine build: Built SR
current power rating: 440 Hp 352 ft/lbs @ 18 psi on 91 Octane
Engine
Blacktop head
Apexi 0.8mm Head gasket
Tomei 270 Solid cams
HKS Cam Gears
CNC’d cumbustion chamber (Mazworx)
Tomei Solid Lifters (Shimmed by Mazworx)
Supertech Inconel Exhaust valves
Supertech Black Nitride intake valves
Supertech Springs, Retainers, and Keepers
3 angle valve job
JWT Bronze valve guides
New OEM rocker arms
New OEM valve Seals
New OEM timing Chain
New OEM Tensioner
Block Assembled by Mazworx (Line bore, Resurfaced, Polished and Balanced, Hone with Tq plate, New freeze plugs, Clean and R/R oil ports)
Mazworx Main bearing oil groove machine work
ACL Coated Thrust washer
ACL coated race rod bearings (19mm Rod bearings)
ACL Main bearings
OEM Oil pump (Black decked with Oil on)
ATI Damper Pulley
CP 86.5mm pistons (8.5:1 compression)
Eagle Rods (Mazworx machined to accept 19mm race bearings)
ARP head bolts
ARP rod bolts
ARP Main bolts (Align honed)
MR Pulley Kit
Blacktop Oil Pickup
Splitfire Coil Packs
Apexi Power filter
Profab intake manifold gasket
Greddy Intake manifold
Tial BOV
Z23 MAF
Tomei Z32 plug wiring
Nismo 740cc injectors
Walbro 255 Fuel pump
Sard FPR/gauge
Enthalpy Tuned ECU
Greddy catch can
Greddy Oil Pan
Greddy Oil Cap
Nismo motor mounts
Powder coated Valve cover
Cooling
Koyo Radiator
Flex a lite dual 12” fans with Thermostat
HKS water temp adapter
Samco Radiator Hose kit
Sard Coolant recovery tank
Garage Defend Cooling panel
Drivetrain
ACT Extreme 6 puck clutch
Toda 10.56 lbs Chromoly Flywheel
Mazworx Z32 Tranny conversion
Mazworx 1 piece drive shaft
Turbo/Exhaust
GT30R turbo (.78 twin scroll turbine housing, T51R style compressor housing)
Full-Race twin scroll manifold
Full-Race 3” downpipe
Full-Race short pipe intercooler
Full-Race Wastegate dump
Tial 44mm wastegate
Steel Braided Wastegate lines
Custom Turbo coolant/oil lines
Greddy Downpipe
Heavy Throttle test pipe
HKS Hi-power Cat Back
Circuit Sports Exhaust hangers
Suspension/Brakes
Stance Coilovers
Suspension techniques Front and rear sway bars
Wilwood 4 piston Brake calipers
Wilwood 12.5” Rotor/Aluminum hats
Steel braided front lines
Hawk Pads
Agency Power Rear lines
Powerstop cross drilled rotors (Rear)
Wheels/Tires
Street
Work XT-7 18x9.5 +12
245/40/18 Falken Azenis
Track
15x7 Konig Rewinds 0 offset
26x9.5 Hoosier Quick Time pro's
Interior
Origin Lab carbon Fiber door Panels
Momo Jet 350mm Steering wheel
NRG Version 1.5 Carbon Fiber quick release
NRG Short Hub
Blitz turbo timer
Kognition CF radio panel
Apex-I SAFC
Apex-I AVC-R
PLX M-300 Wideband
Recaro SRD reclinable buckets
Recaro top mount sliders
Wedge engineering seat brackets
HKS DB meters: Boost, Water temp, oil pressure, oil temp
Fuse Box Relocated under glove box (Wiring plugs installed for easy removal)
Kirk Racing Roll Bar
Summit Aluminum Battery box
Exterior
S14.5 conversion
Origin Lab Sleek front bumper
Front Loop Roll cage
Vis Racing S14.5 +20mm fenders
Vis Racing Carbon fiber S15 OEM hood
Vis racing side skirts
Vis Racing rear bumper
Nissan OEM S15 headlights
Kouki Tail lights
Aerocatch Hood pins
teamsprock is offline   Reply With Quote
Old 09-06-2010, 04:04 AM   #270
bnadeau73
bnadeau73's Avatar
bnadeau73 is an unknown quantity at this point
car: 1989 240SX
trim: S13
color: black
body style: fast back
engine build plan: turbo
current power rating: ~300hp / ~300ft lbs torque
modifications:
The engine:
• SR20 DET engine
• Blitz SUS stainless steel air filter
• Z32 MAF sensor
• Custom-built intake pipe
• HKS GT 2530 Turbo
• HKS Super Sequential Blow-off Valve
• HKS S type intercooler
• HKS aluminum intercooler piping
• HKS silicon interconnects
• HKS type R oil cooler
• SARD 550cc fuel injectors
• SARD silicone vacuum lines
• Nismo fuel-pressure regulator
• Tomei fuel pump
• Tomei fuel-pressure control-module bypass
• Blitz spark plugs
• Yashio Factory coil pack wire harness
• Sun ground wires
• Battery relocated to the trunk
• Earl’s stainless steel fuel lines
• Earl’s oil blow-by lines
• Taka turbo oil lines and coolant lines
• Kazama oil catch tank
• Koyo copper 2-core radiator
• Samco silicon radiator hoses
• Trust (Greddy) water temperature meter adapter
The exhaust:
• ATS-BM turbo manifold and Billion header wrap
• Trust (Greddy) turbo outlet pipe
• ATS-BM front pipe (full length eliminating the catalytic converter)
• Apexi GT spec exhaust
• Juran stainless exhaust ground
• High density rubber exhaust hangers
The electronics:
• Apexi Power FC
• Apexi AVC-R boost controller
• Apexi turbo time
• Apexi scramble switch
• Defi Control Unit II
• Defi boost pressure gauge
• Defi oil pressure gauge
• Defi oil temp gauge
• Defi water temp gauge
The drive train and brakes:
• OS Giken 5 speed close gear kit (forged)
• ATS Carbon Twin Racing Clutch and lightweight flywheel
• Nismo reinforced release pivot
• Nismo GT 1.5 way LSD
• HPI stainless clutch hose
• Z32 rear spindles
• Z32 rear hubs
• Z32 front and rear aluminum brakes
• Yanack rear inner drum e-brake cable kit
• Attain front 5-lug hubs
• 17” X 9J +15 Volk Rays Bronze TE37 wheels
• Yokohama Advan 032 R tires
• Plot Swage stainless steel brake lines
The suspension and bracing:
• HKS Hipermax Pro Pfr Performer coil over suspension
• ARC anti-sway bars
• Apexi front strut tower braces
• Miracle Bar Type 1 rear strut tower brace
• Ikeya Formula tie rods
• Ikeya Formula tie rod ends
• Ikeya Formula front roll center adjuster (180SX)
• Ikeya Formula rear roll center adjuster (Z32)
• ATS-BM / Section front fender brace
• ATS-BM / Section tension rods
• ATS-BM / Section rear camber arm
• ATS-BM / Section rear traction rod
• ATS-BM / Section rear toe rod
• ATS-BM rear sub frame bushing
• Tanaka Engineering aluminum steering coupler
• Nismo transmission mount
• Nismo engine mounts
• Nismo front power brace
• Nismo steering rack bushings
• Nismo rear spindle bushings
• Yashio factory core support guard kiwami
• Do-Luck aluminum floor support bar
• Nagisa Auto shakitto plate
• Full welded-in custom roll cage
• Stitch welded body
• Structural foam
The exterior:
• MSports front bumper
• MSports rear bumper
• MSports side skirts
• D-Max wide fenders (front 40mm / rear 50mm)
• Voltex super canard (Medium)
• Cusco GT type 2 rear wing
• Eliminated the antenna
• Eliminated the rear window wiper
• D-Max Front Crystal Position and Winker Lens
The interior:
• Recaro SPG-II racing seat
• Recaro passenger seat
• Recaro low profile seat rails
• Takata MPH-340R four-point racing harness (driver and passenger)
• Momo deep-dish aluminum steering wheel
• Razo GT heel plate
• Razo pedals
• Nismo leather shift knob
• Kenwood CD player
• Kenwood front speakers
Extras:
• 17” X 8” front 17” X 9” rear Modia racing wheels
• ATS-BM tuned CPU
plan modifications:
• Tomei 2.2 liter Genesis engine
• Tomei Rocker Arm Stopper SR20DE(T)
• Ikeya formula sequential shifter
• HKS GT RS ball bearing sport turbo
• HKS stainless turbo exhaust manifold
• HKS SSQV Racing BOV
• Apexi Super Suction kit
• Attain wide tread wheel spacer
• Ikeya Formula rear knuckle pillow bush
• Front diffuser (Jun)
• Attain aero intake light cover kit
bnadeau73 is offline   Reply With Quote
