#61 |
![]() Join Date: May 2006
I run Shockproof with a mix of MT-90 and it works pretty good when it's cold. I don't know why you guys say Shockproof is junk. It doesn't heat up like regular oil and the viscosity is high enough to not break down. Hell R32 and 33 owners swear by it.
#62 |
I run the Amsoil motor, trans and diff fluids in my s15 sr also. I am also switching over all my other cars too. I just became a dealer so if anyone wants some special pricing on these products just PM me!!
#63 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
Blah blah blah, whatever. You said it yourself in your post. GL-4/5/6/whatever only matters depending on the manufacturer. I'll just ignore all this gl-whatever crap untill I actually have a problem. The neo 75w90 rhd that I am running exceeds gl-5 and gl-6 standards, but for some reason in the 1.5 years of track/street beating I have yet to have a synchro problem. IMO it is all bullshit and depends ONLY on the manufacturer. That opinion will not change untill I personally have a problem. |
#64 |
![]() Join Date: Oct 2004
^^^ I agree, but one thing I can tell you its smoother than all the shockproof redline stuff and that is my test and all I can confirm.
I use redline oil and that is all that goes in my motor, but from my EXPERIENCE Amsoil just made a better gear oil/tranny oil.... Done.... If there is more bickering about standards, I am going to lock this thread.... SSOOOOOO hopefully people can post up their experiences more.
Turn and Burn!
#65 | |
#66 |
![]() Join Date: Jan 2008
FSM says GL4 for trans and GL5 for diff.
Which stuff would I use for the trans? Manual Synchromesh Transmission Fluid 5W-30 or Manual Transmission & Transaxle Gear Lube 75W-90 The 5w30 doesn't say anything about GL4... And for the differential? Quite a few different options.. Severe Gear 75W-90 Severe Gear 75W-110 Severe Gear 75W-140 75W-90 Long Life Synthetic Gear Lube Synthetic 80W-90 Gear Lube I'm getting a Cusco 1.5 way Type RS LSD in this week.. Wondering if I can use the Amsoil stuff or should I just stick with the Cusco LSD oil? If I did go with the Amsoil gear lube, would I need the Slip Lock Differential Additive? |
#67 |
Severe Gear 75w-90 from Amsoil, but I would stick with Cusco stuff.... Never used the Amsoil for the Diff, so just Cusco and when you run out of Cusco just go amsoil I am sure its fine.....
and then Manual Transmission & Transaxle Gear Lube from Amsoil. It says GL-4 right on it, go to the website as I have posted in a couple of posts back. DOne and Done.
Turn and Burn!
#68 | |
#69 |
![]() Join Date: Apr 2007
Trader Rating: (50)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 50 reviews
I use Motul Gear Box 80w90 Mineral Oil. I cant tell the difference but seems to shift
smooth! I was told it was reusable and doesnt break down. what do you guys think! |
#72 |
I think its recycleable because its vegetable oil based, but I don't think its reusable as the additives would surely breakdown over time.
Turn and Burn!
#76 |
![]() Join Date: Feb 2006
I used to run MT90. It was nice at first, then my tranny started getting notchy... I switched to Penzoil Synchromesh on Friday, and it feels 100x better now.
#82 |
Look up on their website.... AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases
Never tried their auto stuff, but I am about to for my acura TL.
Turn and Burn!
#83 |
![]() Join Date: Sep 2006
nice thread and good info in here. i just swapped my sr into the new shell with a new (used) trans and was debating what oil to use. i'm def gonig amsoil now. i swapped in a ka trans with sr bellhousing, and before putting the bellhousing on i had to beat the shit out of the drain and fill plugs. the last owner sealed them shut. long story short, i had to apply heat and now need new plugs
#84 |
Some good info here... so Amsoil or Motul then?
My 3rd gear has been grinding ever since i got the car so a while back i replaced the gear oil with Royal Purple... now i'm noticing that when its cold, the transmission shifts like butter in every gear, and i can even jam it into third without a chirp, but once it warms up, 3rd starts grinding as usual and all the gears, in general, dont shift as smoothly as they do when its cold. What would be my best bet?
(function)(form)^(-1) |
#85 | |||
They fail.... Quote:
#86 |
Man w/ CTSV & a Car Seat
K I need some input. My tranny's starting to grind 3rd gear, the wierd thing is it only does it when its wam and its only that gear. Im currently running RP 75-90, I got a spare tranny but I would rather change the oil first to see if that alleviates the problem. I figured since it runs better when its COLD, im thinking i should empty some of the 75-90 in there and toss a qt of 75-140 RP in there to ticken it up.
But people are talking about AMSOIL being the shit, only AMSOIL i found out here is 80-90. So Im torn which route I should try. |
#87 |
@ineednewtires
could you suggest a particular brand/product though? with all this talk about amsoil in this thread, I'm considering giving it a shot, but I'd really like to know beforehand if its possible that it will solve my grinding. @fliprayzin240sx lol, thats almost exactly the issue I posted about 2 posts up.... other suggestions? i
#88 |
![]() Join Date: Jun 2004
a change of fluid might be enough in itself. i remember i used to grind 3rd in my s13, but after changing the fluid (from some accidental gl-5 to gl-4) the problem went away. go with any good fluid and if nothing changes, then it's not gonna be solved with oil.
#89 |
UPDATE!!! Lol funny you guys are talking about this. Man literally I tried all of the oils, and you NEED Amsoil for tranny.
Manual Transmission & Transaxle Gear Lube 75W-90 Product Code: MTGQT-EA You can order via this site AMSOIL Synthetic Automatic and Manual Transmission Fluid I don't think they will ship overseas cause its oil maybe? If NONE of you guys can find some I have a local place that carries ALL of the lines of Amsoil. I can get it for you guys pack it and ship it. Place is called Vic Hubbard in Hayward, but like I said I can ship it if you guys can't find it. Let me know. I switched to this as I tried to the Sever Gear from Amsoil and this one is better.... I just did it over the weekend. Immediately noticed the difference.....
Turn and Burn!
#90 |
![]() Join Date: Nov 2003
I'll say it to everyone I know who owns a nissan 2.4/2.0 manual trans, Lucas HD 85w-140.
Beats all except in extremely cold weather.
Lower than a pornstar's morals. |
