#61 | |
I just contacted both All Star and Flaming River. Both are too short to reach the bottom of the rack on the high pressure side. All Star is .740" and the Flaming River fitting is .840". OEM is .969". |
#62 | |
![]() Join Date: Jun 2011
Are both the rack and fitting steel? |
#63 | |
As for weld-ons, Earls has alum, steel, and stainless; OEM box is steel. Additionally, the steel weld-on bung is only $4. I would weld it in a glove bag back-purged with argon though, just in case. |
#65 | |
#66 |
Though there is certainly nothing wrong with this approach, it is easier said than done. To remove it to be 100% flush, or even close to that, you will need to set it in a vise, whether for machining or for hand-grinding; and there is no good surface to clamp to for using a mill. You may be able to clamp on to the outlet/inlet ports that feed to the crossover, but then, you will need to remove material by hand since it will be out of tram with the mill.
#67 |
#69 | |
#70 |
Looks like they milled the face off quite a bit, likely to get that banjo to work. I've never seen a very long banjo bolt to fit this application, though I did not really look too closely. I still see a copper crush washer, which I do not trust and banjos will never seat in the PS box properly. Moreover, I wouldn't trust to use thread dope or thread sealant since that's a banjo fitting.... Basically, your sealing comes from a crush washer. No thanks
#71 |
I got in my Fueled Racing stuff the other day. All they do is buy the Fragola PS fittings and turn them on the lathe to knock down the hex head a bit. Installed, they don't even come close to the hex when fully tight. I feel pretty certain that these will not leak:
#73 |
#74 |
![]() Join Date: Jul 2009
if anyone needs a custom fitting an flange for the rb25 powersteering reservoir to feed on pump i can have that fitting made for you $45 shipped. Its a flange with a -10an fitting machined
#76 |
Any pictures of this? I am interested.
S12 || KN13 || S13 || B16 |
#77 | |
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Seems like bc. made his own lines retaining the stock fittings..
#78 |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Dam i forgot about this thread!!
for the rack side high-pressure fitting i ended up having a custom fitting made out of brass for this, basically i copied the dimensions of the hard line on one end and a -6AN on the other, i will try to get pics when i get home.
#79 |
pirtek makes custom lines to specification for cheap, and they will never leak. My whole oil relocation and boost/vacuum lines were all made by pirtek. I only have one hose under the hood with a clamp on it (other than intercooler piping and radiator hoses).
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
#80 |
![]() Join Date: Jan 2010
Trader Rating: (26)
I used a Nissan Titan setup for a while. Worked flawlessly and not too much modifications needed. I wish I saved some pictures somewhere. I may roll with this when I finish my next car, doe.
#83 |
Damn epic stuff. I'm going to be pluming in a B&M supercooler (72005 model) for my p/s coolant. Not gonna run AN lines at the moment. I'm too lazy
![]() But, this really helped me figure out how to run my cooler! Anybody have any concerns that most aftermarket coolers and AN-6 lines are ~8.75 mm (3/8") and the Nissan uses metric lines? The low pressure return to resevoir nipple measures in a 9.75mm on my car, and it's a bit of a snug fit for a 3/8" ID hose. |
#84 | |
![]() Join Date: Oct 2007
I Just cant find one long enough !?!? |
#86 |
Here are the Allstar part numbers.
Power Steering Adapter, Steel, Zinc Plated, -6 AN Male to 14mm x 1.50 Inverted Flare ALL48211 Power Steering Adapter, Steel, Zinc Plated, -6 AN Male to 16mm x 1.50 Inverted Flare ALL48210 After a few minutes on the lathe. ![]()
#89 |
![]() Join Date: Jan 2008
Any links to what/how to adjust the flow with the pump? I have 1 or 2 extra power steering pumps lying around and would like to try it.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z -Shake N' Break Racing- |
#90 | |
Or you can put in a variable pressure regulator but those run around $250 iirc. |
