Old 12-24-2005, 01:07 AM   #1
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
Z32 MAF Install SR20DET (Pics)
Well here is my next addition. I have a shitload of parts I have to install, today I tackled the Z32 MAF. Easy right? In and out? Well not exactly so I made sure to document the Issues I had and the fixes. There are more than one way to install. This is myway and it worked:
Items Needed:
Z32 MAFS
Intake that fits the Z32 MAFS
80MM Grommet
2 80mm Hose Clamps
80MM to 60MM Aluminum Pipe
Wire Harness
Steel bar for support
Electrical Tape
Wire Connectors
Tools
This write up may help. If it does, give me some points please
**Disconnect your negative Battery Terminal**
Okay well getting started, I ran into an immediate problem. The Z32 MAFS intake side did no fit the APEXi Intake I had been usuing with my stock MAFS.
Fix was, I bought a new APEXi Intake. I swear by the APEXi, my old one with adapter piping is for sale as well.
Okay to attach the MAFS to the Intake depends on the intake itself..make sure you keep hold of the little rubber gasket ring that goes bewteen the MAFS and the Intake, it sits in a little valley type area on the MAFS. Then use a paper style gasket between the intake and the MAFS and use the 4 screws to secure it nice and tight.
Okay now pull out your old MAFS and Intake and you will see the next problem.
The Stock MAFS has an 60mm exit to the stock compressor pipe...your new Z32 MAFS has an 80mm one. I eventually plan on getting a full aluminum pipe made that will go all the way up from the compressor to the intake, but for now I had to improvise cause I hate to stop in the middle of sh1t unless it is for beer or good head from a hottie...so what I did was headed down to the speed shop and bought an 80mm to 60mm reducing pipe and a gromet...
See you can't just use a reducing grommet, becuase the stock compressor piping is rubber if you used a rubber style gromet it would collapse..you need something strong in there that wont collapse. Use two hose clamps and attach the MAFS with installed intake to the Reducing pipe using the grommet. Once your done it should look like this, mine looks like an F15 motor now:
Then put the pipe in. You can slide it down the stock rubber compressor tube and use the stock hode clamp to secure it on the 60mm end of the reducter. Push it in as far as you can, there isnt much room. It will look like this now, and yes I had just enough room...
it is time to cut the harness you are looking at in the picture above....make sure you cut it about 2 cm's from the tip. This way it can still be used again.
Then get your wire diagram and wire the stuff up:
Here is the breakdown using the Harness I bought for 20 Bucks..
From Right to Left:
White - to White on the stock Harness
Black - to Ground on the car
Black - to the Black on the Stock harness
Red - to the Black and White stripes wire on the Stock Harness
Attach all of the wires from the new Z32 Harness to your stock wire cluster...use the direction above. You can either solder the wires (preffered) or do what I did. I just used wire connectors and crimped them together, then wrapped the harness in black tape. I didnt wanna do it permanantly with solder yet since I am going to have an intake pipe made for me later and may have to reduce the harness length.
Then you will still have the ground wire to deal with...I extended the ground wire and set it right below my profec motor..but there are plenty of places to ground it at..
Okay now here is what the finish product will look Like installed...The only thing left to do is reconnect your battery cable and start up. If you have an SAFC II like me, you will have to make an adjustment in the ETC menu prior to startup. Go into ETC, choose Sensor Type, choose HW and In "2" and Out "6":
Next write up is 550's and AEM UEGO wideband install
Late
Daryl
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 12-24-2005, 01:35 AM   #2
HyperTek
I didnt know the Shocker was required for the install.. hehehe jk.. Nice write up
Keep it Classy
Old 12-24-2005, 02:55 AM   #3
caall99
caall99's Avatar
caall99 is an unknown quantity at this point
Send a message via AIM to caall99
your write-ups are awesome! keep em comin'!
Signature over limits
#/f/showthread.php?t=21036
caall99 is offline   Reply With Quote
Old 12-24-2005, 03:35 AM   #4
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
We should make your own section, you are the bomb diggity. +++++
95zilvia is offline   Reply With Quote
Old 12-24-2005, 03:47 AM   #5
kuramaya
Wow Thanks Guys! That means a lot..I have a few I havent posted...like the Acuator Install I did last weekend when I though mine was bad
you guys could always give me some rep points
J/K
Late
Daryl
Old 12-24-2005, 07:05 PM   #6
kuramaya
Thanks for all the Rep's guys!
Old 12-24-2005, 07:52 PM   #7
vutony
vutony's Avatar
Trader Rating: (144)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 144 reviews
nicely done....this was gonna be my next mod and now made it much easier
vutony is offline   Reply With Quote
Old 12-24-2005, 08:33 PM   #8
kuramaya
Glad I could help!
Old 12-25-2005, 10:23 AM   #9
vutony
vutony's Avatar
quick question...would the install with a R33 maf be the same...which is better the Q45 maf or Z32 maf...lmk....thanks
Old 12-25-2005, 11:40 AM   #10
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
awesome write up daryl. as stated before you are the BOMB lol
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 12-25-2005, 04:17 PM   #11
kuramaya
Thanks WIldace!!!
Z32 Flows better than the Q45...There is not a better MAFS to use...Discussion came up locally and found out nothing beats the Z32...now are you saying you want to install an RB25DET or RB26DETT MAFS on an SR20DET? I wouldnt do it...The GTR MAFS have no where near the flow as the Z32..I can prove it if need be with a test done..but I would have to find the file to upload..
Late
Daryl
Old 12-25-2005, 04:59 PM   #12
ThatGuy
Admin Asshole
ThatGuy's Avatar
Very well done, bjorkluv. Thank you for adding something positive to Zilvia.net.
Old 12-25-2005, 05:17 PM   #13
vutony
vutony's Avatar
Originally Posted by bjorkluv
Thanks WIldace!!!
Late
Daryl
its goin on a sr20...i probally gonna get the z32 anyhow...thanks
Old 12-25-2005, 07:31 PM   #14
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
copied into archive
Originally Posted by PHLIP
Old 12-25-2005, 08:35 PM   #15
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
awesome writeup! excellent work
nsn240 is offline   Reply With Quote
Old 12-25-2005, 09:24 PM   #16
kuramaya
ThatGuy - Thanks Brother, Semper.
mrmephistopheles - Woo Hoo, my second one in the archives
vutony - Yeah Get the Z32 man...
nsn240 - thanks brother
Old 12-26-2005, 12:23 AM   #17
mr_240sx
mr_240sx's Avatar
mr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfection
Send a message via AIM to mr_240sx Send a message via MSN to mr_240sx
awesome write up bro!! i have to tackle that in next month or so.... ive had my z32 maf sitting on my night table since september.... but ive been really busy with work so hopefully ill get time before spring to install it!
mr_240sx is offline   Reply With Quote
Old 12-26-2005, 12:34 AM   #18
kuramaya
Thanks man...woah your pink
Old 12-26-2005, 08:05 PM   #19
Nofatchicks
Nofatchicks is an unknown quantity at this point
im still wondering how it needs a write up. I know many people who did it and never had a problem or expierence. I did it myself without even a diagram since Heavy Throttle forgot to send the paper work for the turbo upgrade kit. I did the injectors, Z32, and install all without paperwork.
Nofatchicks is offline   Reply With Quote
Old 12-26-2005, 08:11 PM   #20
kuramaya
Congrats!!!!!
1. Everyone is not as cool as you.
2. Some May have questions before they do an install like this.
3. SOme do not want to jack their sh1t up so search to see if someone has done the same install before, this will be there for them in that situation.
Old 12-26-2005, 09:38 PM   #21
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
no fat chicks just got served
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 12-27-2005, 08:51 PM   #22
Nofatchicks
You must not be the smartest person in the world if you cannot install it. Its 4 wires and 4 bolts. Seriously.... darwinism is in effect. Too stupid to install... too stupid to drive. HAHAHAH
Old 12-27-2005, 08:59 PM   #23
mr_240sx
mr_240sx's Avatar
easy ...... this question is asked quite often so i think its great that theres now a How-to on this,...... hopefully it will stop all the new threads asking how to do it.
Old 12-27-2005, 09:31 PM   #24
ThatGuy
Admin Asshole
ThatGuy's Avatar
NoFatchicks, at only 8 posts in to Zilvia.net, I do not appreciate your attitude or how you choose to treat other members. You are PINKED for 3 months. Hopefully you will learn to get your point across without trying to belittle others. If you don't, your time on Zilvia.net will be cut short.
Old 12-27-2005, 10:20 PM   #25
kuramaya
Really man, it may seem easy to you. Was easy for me. People like pictures and they like to read ahead when installing parts. Everyone is not comfortable with tools. The purpose, well one of the purposes of forums like these are for sharing information and helping each other out. I am a member and moderator of other forums and try and share my knowledge. There was a time 15 years ago or so that I could not change the oil in my own car...those people are still out there. They are learning. A thread like this is not designed for opinions that are negative. I took pics and Typed a whole lot of sh1t to make the write up. I am a Jarhead so typing is not that easy for me. If you don't think the post is worthy move on and Have a nice day.
For all that are interested here is a write up I did on installing some fuel components:
#/f/showthread.php?t=94575
I plan on installing a wideband and 550's this weekend, we will see if the weather holds up..
late
daryl
Old 12-28-2005, 04:26 AM   #26
tailwaggin91
tailwaggin91 is an unknown quantity at this point
Don't know who's aware of this or has more info, but I was advised that you should look for an orange sticker on the airflow meter. Luckily mine was correct, but I believe it's color coded by engine, orange being VG30DETT. Sorry if it's already known, but I thought it'd be appropriate to post in an install section.
tailwaggin91 is offline   Reply With Quote
Old 12-28-2005, 05:20 AM   #27
kuramaya
You are looking for these numbers/letters on the MAFS. You can see in my firt pic if you zoom.
22680-30P00
Old 12-28-2005, 05:42 AM   #28
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
Hey thanks for the step by step install of the MAF. I just picked up an S-AFC today and I was thinking on installing it along with my z32 MAF tomorrow. Your thread just made it alot easier for me. Now I don't have to figure out the cables, thus saving me a lot of time. Since I'm in Japan I'm still trying to figure out two cables from the S-AFC since everything is in Japanese. I can read a little hiragana and Katakana, but not Kanji (three different type of writing in the Japanese Language). Any how, thanks again for your post and don't pay attention to the haters. LOL I'll post pics of my set up once I'm done with it. Peace!
TOMKAIRA93 is offline   Reply With Quote
Old 12-28-2005, 02:18 PM   #29
kuramaya
Hey I am in Okinawa too, I have english manuals for the install. But you can download the english user/installation manual here:
http://www.apexi-usa.com/support_installation.asp
and also the wiring diagram for installation here
http://www.apexi-usa.com/support_wiring.asp
Also there is a forum for all of us car guys on Okinawa, I am Kuramaya on there:
http://www.zeroyon.com
Just tell them I sent ya!
Old 12-28-2005, 02:56 PM   #30
TOMKAIRA93
I just looked at the diagram in english and it doesn't match the japanese one. The english one says 240sx so am assuming its for a KA application and not SR.
For some reason I went to this site yesterday and couldn't find anything. I downloaded the manual, like 50 pages, and didn't find anything. I think I just need to figure out one more cable and I'll be alright. Thanks again for all the links, I'll try the Oki forum. Thanks bro!
