![]() Join Date: Jan 2004
![]() ![]() ![]() Feedback Score: 4 reviews
vq35de engine in s14?
how much do u think i could pull it off for ? and does it even fit , lastly if i get state reffed will it pass thier inspection becuase it is a u.s motor?
how 'bout you research local emission laws. ill tell you tho, it will pass and it does fit. go so sport compact car magazine website. a google search wouldve sufficed better than a thread. now you know.
Expect it to take you atleast a year if you have decent skill. You have to use stock headers/cat and all that though for it to pass. Allll the emissions and vacuum line as well obviously. Adds a lot more difficulty
I'm from Florida so I'm probably a bit more strange than you |
#6 | |
![]() Join Date: Jul 2006
just use the search, shit... http://forums.nicoclub.com/zerothread/146631 how about you kick it there from now on...
Robby Leuer
best place to go is here...
http://www.engineswaptech.com/forums/3/ShowForum.aspx I pondered this idea also. The only problem with getting it to pass smog is the wiring. Speaking with a few people here and there, and also on that forum, the 350z wiring harness is integrated into one whole harness rather than having a seperate harness for in dash and engine etc. This could cause a problem with the ECU throwing CEL codes during refing. |
#8 | |
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
![]() Join Date: Aug 2006
I'm using an ECU and wiring harness from a Maxima on mine. The Maxima harness is pretty easy to use and is definately seperate from the chassis harness. The 350z engine harness is seperate too though, I've compared them both and both will work fine.
One problem you will have is getting the stock Z cats to fit if that is a requirement for your state. They will hit the firewall on the S14, you could get around that though, it's not impossible. Heck even the electronic "gas" pedal bolts right in like it's meant to be there (get one from a Z, not a maxima). Fred www.engineswaptech.com |
