![]() Join Date: Jan 2004
YOUR suspension setup to Prevent UNDERSTEER
my s13 coupe understeers like a mofo... just wonder what your suspension set up is (coilover, tire pressure,chasis reinforcement, etc) that prevents understeer and produce more oversteer.
current set up front tires 35psi back tires 40psi eibach prokit spring tokico blue shocks suspension tech sways ebay front and rear strut bars john... |
![]() Join Date: May 2002
mm
tanabe dd NO FSTB NO aftermarket front sway bar tanabe rear sway rstb good tires front and rear pressure like 32? my s13 was tein HE rstb (no fstb) do luck f and r ladder bars s13 jdm rear sway, stock usdm front sway bar tc rods all rear suspension arms replaced do luck rxb i think thats it... NEVER had an understeer problems also WHAT front/rear tires you running alignment? your toe might be f'd up. when was the last time you got an alignment???? might be out of spec also do you run a diff? a 2 way will add some push while doing grip |
![]() Join Date: Apr 2005
Tein HEs
No FSTB Cusco Type OS RSTB JDM Hicas Rear sway (doesn't seem that large) PSI at 36 all around(street/daily) NOTE: as stated earlier with a 2-way on initial throttle when cornering you will push. you need to break the limit of adhesion to drift, unless you clutch kick, e-brake, feint, etc.... or other ways to break the rear out. simple cornering to make the rear come out isn't going to happen.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 |
Here is a good link that tells you what to change to get more understeer, or oversteer.
http://www.autornd.com/Merchant2/mer...SUSPENSIONTUNE I run----> Tein HE-(-1.0* to -3.0* camber front) SPL-front tension rods (8.5*to 9.0* caster) SPL-RUCA (0.0*to -0.50*) Nismo-front under brace C-Tune-front and rear strut tower bars P2M subframe spacers 32psi to 35psi for the tires, sometimes I will run like 40psi in the rear for smoke. I like a slite toe in on the rear, and slite toe out up front. Oh and run good tires up front. ![]() |
I set my dampening in the rear slightly stiffer than the front.
I'd say the most improvements can be made in the way you brake. For instance, in a series of corners that are all in the same gear, I'll use left foot trail braking with quick transition throttle. If it's a turn that requires hard braking and downshifting, I'll make sure to brake earlier and smoothely and ride the brakes into the turn for some trail braking grip. |
![]() Join Date: Jan 2003
silkroad coilvers, tanabe rear sway bar, stock front sway bar, front and rear strut bar, almost all arm replaced with aftermarket
1990 s13 IslandMotorsports, Inc. |
#8 | |
I am so sorry I was just speaking from personal experience.
EDIT: Actually I searched on google and my comment seemed to be right. http://www.ffcobra.com/FAQ/handling101.html http://www.tirerack.com/tires/tirete....jsp?techid=58 http://www.autornd.com/Merchant2/mer...SUSPENSIONTUNE It is even stated in the link provided by zootang above. Now, don't you think your response was a little too harsh? Even if I was wrong, you did not need to be so rude and ignorant. You could've just corrected me in that case. I won't do the same thing you did to me so there, you know it now. Last edited by SaGang227; 05-02-2005 at 01:43 AM.. |
#10 | |
(i thought that lowering the front tire psi would give more grip in the front= more oversteer... ) |
![]() Join Date: Apr 2003
Air pressure vs. Grip is like a bell curve.
Too little pressure and you lose grip, too much pressure and you also lose grip.
Jason '95 240sx SE |
#12 | |
for fsae we set a few days aside for tire pressure testing alone with our sensor/aquisition system to get a decent curve for diff temps. |
![]() Join Date: Mar 2003
Tanabe sustec pro type II's (run 4 8, sometimes autoxing i run 3 6 to compensate for tight turns)
ST sway bars KTS hard toe, traction, rear upper pro arms KTS hard t/c rods, nismo power brace Kazama subframe collars 3 point strut bars Project MU dura camber plate, tanabe pillow ball on the rear -1.5 degrees camber front and rear 42 psi in all four falken azenis oem vlsd understeer is pretty much eleminated. I do get a slide when i got into a hard turn too fast most of the time i can compensate. For the most part its all grip. |
I also vote for Nofrontswaybar.com hahah
EDIT-Opps I meant Nofrontstruttowerbar.com hahahhaha my bad... idiot!
Keep it Classy Last edited by HyperTek; 05-03-2005 at 01:17 AM.. |
yo John. I used to understeer a lot until I got none stagger or close to none stagger tire setup.
Also there are a few tricks that you can do to really understeer without sacrifice front stiffness. 1. Load up the front with negative camber. I am talking about -2.5 or more degree. 2. Get really grippy tires in the front. I am running Falken azenis sport in the front and some cheap 711 in the rear. (Really be careful in the rain with that tire in the front) 3. Get coilovers and set the front to soft and rear to hard. I usually like to have rear on the stiffest to start the event and slowly soften it up as the tire wears out on the rear to balance the traction. I run front and rear sway, front and rear strut. Really you don't have to take the front sway away. Don't listen to the other BS. Keep ur front stiff and just make the rear stiffer or give front more traction. My suspension setup Silkroad RM8 coilover Silkroad rear toe adjuster Silkroad rear upper control arms Front Cusco tension rods Front and rear ST sway bars Front cusco CF strut bar Rear OS strut bar Next for me is front tie rods and tie ends upgrade. And I would probably stick with this setup for until I get more engine work done. By sometime summer of next year. I am gonna have Rollbar or Cage, fender brace, and possibily seam/sport weld the rear.
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. Last edited by ghostuss; 05-02-2005 at 11:42 AM.. |
#17 |
yea and that smoke effect is so cool, except if you can't drift a low powered car = you still suck in drifting.
96 all suspension s14 SOLD 90 s13 coupe - SOLD Currently rocking 2002 BMW M3 w/ custom suspension. ![]() ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only. |
#18 | |
wnat it to push so wont spin? HAHAHAHAHAH only if you suck at drifting. are a fucking newb. depend on power to rotate and cant tune a car's suspension. basically your a jackass newbie poser. yeah. fuck yeah. |
#19 |
Hey asshole, I've been drifting for two and a half years and I've won a few mini-comps so blow me. And I just went SR at the beginning of this year so don't tell me I can't drift with out power douche.
Yeah I'm a jackass...cause I only have 400 posts. Fuck you. All I need is someone to host and I'll post vids of LAST years drifting with a KA and my "newb" drifting. |
#23 | |
what do you mean by stagger??? |
#24 | |
