![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
TURBO VQ35 Swap/Bride/RC/ETS/GARRETT/ TONS OF 240 PARTS for S13,S14,S15/SR20DE,VE,DET
OLD THREAD...CHECK FOR MY NEW ONE!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave! 2. If you PM, please also bump the thread. 3. Im always adding more parts and pictures to the thread, so check back every so often. 4. More parts have been added as of...7-4-11 Engine and trans have about 25,000 miles on them and run perfect...will come with: (IM WILLING TO PART IT OUT!) Engine (High Rev) 6-speed Transmission Clutch Flywheel Wire Harness ECU Solid Motor Mounts PRICE DROP: $2300 OBO Custom VQ Turbo Setup has about 500 miles on it. Comes With: (IM WILLING TO PART IT OUT!) Custom Manifold w/ Downpipe (V-Band) Tial Wastegate (V-Band) Garrett 3076 Ball bearing Turbo (V-Band) PRICE DROP: $2000 MORE PARTS FOR SALE! Bride RHD S14 FRONT Floor mats (Imported from Japan) - NEVER USED - PERFECT SHAPE - $250 ![]() Turbosmart Megasonic BOV - Roughly 1k miles - PERFECT SHAPE - $150 ![]() Unknown Brand BOV - Slightly Used - PERFECT SHAPE - $50 ![]() Kouki Tail Lights - SOLD! - NEVER USED PERFECT SHAPE - $275 ![]() S15 Hoods - NEVER USED - $250 RC 1000cc Top Feed Injectors - NEVER USED - $325 Kisuu Custom Made Billet Top Feed Fuel Rail - NEVER USED - $175 ![]() ETS Custom Made Intercooler 24X8X3 - NEVER USED - PERFECT SHAPE - $175 OEM Redtop Injectors - USED - PERFECT SHAPE - $50 ![]() Origin Canards w/ Custom Aluminum Under Shield - NEVER USED - PERFECT SHAPE (shiny parts are just the flash from the camera and some of the mounting holes) - $180 ![]() S13 Black top ECU -Perfect SHAPE - $125 ![]() Garrett 3071 BB Turbo with 4 bolt turbine housing - ~300 miles - PERFECT SHAPE - $1100 ![]() Battle Version S13 Tension Arms - SOLD! -Used -PERFECT SHAPE - $110 ![]() ROSS TUFFBOND Harmonic Balancer (Rated to hold 1500hp and retails for almost $500) -ONLY MOUNTED -PERFECT! -$400 ROSS TUFFBOND Water Pump Pulley -ONLY MOUNTED -PERFECT! -$100 ![]() ![]() Z32 MAF W/ Pigtail - SOLD! - PERFECT SHAPE - $85 ![]() S14 KA24DE ECU (Callum Board Chipped) - PERFECT SHAPE - $190 ![]() KA24DE OBD2 to OBD1 Harness - SOLD! - PERFECT SHAPE - $100 ![]() S14 SR20 88.5mm Cometic Metal Head Gasket multilayer - NEVER USED - PERFECT SHAPE - $70 ![]() KYB S13 Struts - USED - Great Shape - $150 ![]() OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - MAKE OFFERS ON WHAT YOU NEED! ![]() ![]() Peakboost Downpipe - Roughly 500 miles - PERFECT SHAPE - $100 S14 Non-ABS Driveshaft - Used - $120 S13 Non-ABS Driveshaft - Used - $120 S13 SR Transmision - SALE PENDING - Roughly 30k miles - PERFECT SHAPE - $150 These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread. S13 SR OEM Coil Pack Cover BNIB SR Multi Layer Exhaust Gasket BNIB OEM SR Exhaust Gasket SR OEM Exhaust Manifold w/ Heat Shield (1) V1 Godspeed S13 Toe Arm (1) V1 Godspeed S13 Traction Rod BOV (i think it was a turbo XS...i have had it in my garage for almost 3yrs) Valve Cover Gasket Valve Cover Coil Plug Gasket Water Outlet Water Inlet (4) Cam Oil Tubes (2 Sets) (16) OEM Spring, Retainer, and Keeper (1 set) (8) SR OEM Intake Valves (1 set) (8) SR OEM Exhaust Valves (1 set) (8) SR OEM Rocker Arm (1 Set) (8) SR OEM Lifter (1 Set) SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop) SR20 Front Cover w/ Oil Pump (2) Oil sandwich plate Galley w/ sensor (2) Upper Oil Pan (2) Water Pump Water Pump Pulley (3) Rear Crank Case Cover Crank Pulley (4) SR Oil Squirters (1 Set) (3) SR OEM Rod (4) Upper Oil Pan Screen (2 Sets) (3) Different SR20 Timing Chain Guides (3) SR Timing Chain Tensioner (2) SR Main Cap Girdle (2) Alternator Bracket AAC Valve (3) Knock Sensor (3) Coolant Tubes (2) Thermostat Housing (2) Coolant Temperature Sensor Housing 3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler Turbo Blanket (was on a T67) SR Transmission Plate SR OEM Turbo Lines S13 Rear OEM Chamber Arm S13 Rear OEM Traction Arm S13 Rear OEM Toe Arm stock KA24de fuel pump (in working order) stock KA24de header + stock heatsheild stock KA24de airbox intake system and Filter is still clean Summit Liquid Fuel Pressure Gauge SOME PHOTOS, MORE TO COME! ![]() ![]() ![]() ![]() ![]() ![]() FWD SR20DE...EJ20...SR20VE- If you need any parts for one of these motors, let me know…im sure I’ll have them.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 10-05-2011 at 12:42 AM.. |
Pm sent on S14 ABS Driveshaft
http://allies-drift.blogspot.com/
#5 | ||
Trader Rating: (18)
pm sent back, hopefully we can do this, this weekend at FD
https://instagram.com/eck_matthew/ |
#9 | |
Trader Rating: (18)
Yes, i still have the mats.
i will get you a pic as soon as possible, too.
#12 | |
Trader Rating: (18)
LOTS of parts are currently pending sale untill after East Coast Bash since alot of people would like to meet there to buy the stuff. Also, i did a price drop on the VQ motor and turbo setup...buy whats left before its all gone, guys.
s13 sr20??
hey do u have the stock s13 sr20det rubber pipe that connects to the turbo.. i don't know the name... but it's the one that the maf and air filter connect to??? if so please let me know?? i also need an oem sr turbo line... thanks
#15 | |
Trader Rating: (18)
sorry, they sold.
#20 | |
Trader Rating: (18)
DID A PRICE DROP ON ALMOST EVERY PART! also, more parts have been added to the thread today, i will get pictures for more of the items this week. Last, i am willing to part out the engine setup and the turbo setup.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 06-26-2011 at 09:06 PM.. |
#24 | |
Trader Rating: (18)
hopefully this weekend we can meet up and get you that trans.
#25 |
![]() Join Date: Oct 2006
hmmm any more pics of the turbo setup on the vq? I'd like to see how the headers and downpipe were routed. Also, any more information on the headers themselves, what kind of material, how they were welded, etc. Thanks
#27 | |
Trader Rating: (18)
i'll get you pics of the downpipe, but no, i dont have the adaptor.
#30 |
Trader Rating: (18)
dont really want to part it out, unless someone wants the engine or trans first.
hah yeah, it would be a good swap into alot of cars. im surprised no one has picked it up. this is priced cheaper then alot of non HR vq engine sets.
