![]() Join Date: Oct 2013
Ka24det problem crank no start
Bought this shell it has a boosted dual cam in it apparently the bottom end was built CP pistons 9.0.1 and eagle rods ARP rod main and head bolt studs
Fuel pressure with key on 39 Cylinder 1-4 averaged 118-125 with throttle plate closed cold engine sitting for 3 months My understanding compression should be in the 170s in stock ka24des So in my mind 9.0.1 pistons should not equal 120 across the boards So im thinking Head gasket or ring lands Car will start sounds really strong almost wants to catch but dosent What do you guys think O his nistune has no base tune I swapped it out with a stock ECU from amy other running s13 I have in my yard no changes same symptoms I'm stumped any recommendations?? |
![]() Join Date: Feb 2011
check the timing on the cams in relation to the crank, if any of the timing components are off it will give you false hope no matter how many times you start it
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240.
