5 stud(lug) conversion using z32 parts.
ok,
atm i have an Aus Spex N/A z32 wreck in my garage, i have everything from the driveshaft back and all the front suspension/brakes ect. i'm picking up my new s13 tomorrow and its 4 stud(lug) so obviously i want to go 5 stud(lug), i know to use the z32 rear hubs i need to use z32 half shafts between the hub and the diff but they wont fit because of the N/A S13 diff. if i was to take the z32 diff, the z32 halfshafts, the z32 hubs and the brakes would it be as easy as swapping the covers on the diffs and then bolting them onto the s13 rear end? also, i know i need s14 LCA'S for the front but are the hubs useable or have i got a whole heap of gear i cant use? cheers guys |
If the S13 had a R180 diff you'll need to swap the entire rear subframe from the Z. The R180 diff cover won't work on the R200 housing and the R200 cover won't fit in the R180 subframe. You can swap to 5 lug though without changing the halfshafts.
