![]() Join Date: Feb 2002
*NOW IN STOCK*
_____________________________________ The GKTECH high tensile 4130 zinc coated offset tie rod extenders screw on to the end of either standard or aftermarket tie rods and allow the tie rods to travel further into the steering rack which creates more steering lock with the added bonus of moving the tie rod position forward 25mm's which helps reduce steering bind. Great for drift or getting out of parking spots. The offset rack spacers are a great alternative to moving the steering rack forward and offer 17mm's extra lock without compromising on the amount of thread left in the steering rack. ______________________________________ Click here to order ===> http://www.enjukuracing.com/products...extenders.html
There's no specific boot designed to run with offset rack extenders. You might be able to pull a factory boot over these but you will run the risk of them tearing. Most often, people run no boot with these spacers.
