#31 |
![]() Join Date: Jun 2012
Don't ever buy from Osaka!!!! Ever!!! My S14 SR20det came with the wrong Ecu and Maf no ignitor chip, a fucked up harness with broken clips a turbo that had a 4in metal wire wrapped along the fins seizing the turbo . Not to mention the turbo was completely rusted on the inside and on top of all that it came with a blown head gasket! Don't keep giving these scumbags your money. Save yourself lots of time and money and go to other reputable places and not get screwed by Osaka like I did. If you don't believe me do what i should have done and do some research on them and how others have been fucked over also.
#32 |
ENGINE PRICES PARTS TRANSMISSION
TOYOTA ENGINE 1- 2jz vvti r154 transmission hks clutch 1 - 1jz Single turbo Modifed auto wiring ecu 3 - 7mgte auto : 3 - 7mgte R154 wiring ecu 5 - 2jztt vvti auto wiring ecu 7 - 2jztt non vvti auto wiring ecu : 4 - 4agze full wirng ecu transmission : 1100$ 4 - 3sgte mr2 94+ wiring ecu trans lsd : 2 -3sgte mr2 91-93 model wiring ecu transmission: 2 -3vz-fr manuel 4wd transmission : 1 -3sge beam harness ecu auto : 3- 3sgte celica 4wd transmission wiring ecu : 5- 5sfe coil pack model engine auto trans : 96-00 : nissan engine : 1 -R32 RB26DETT COMPLETE 5SPEED SWAP + BREMBO DIFFERENTIAL DRIVE SHAFT + FRONT END : 3 - sr20det s15 6speed wiring ecu : 10- sr20det s14 5speed wiring ecu : 10- sr20det s13 mt redtop /blacktop wirnig ecu : 10- rb25det mt transmission wiring ecu : 5- rb20det mt transmission wiring ecu : 1- sr20ve FF at harness no ecu : 1 - ca18det wiring ecu transmission : 1 - vg30dett auto transmission : mazda engine : 3 - 13b-tt wiring ecu transmission MT : 3 - 13b-t wiringe ecu transmision MT S5 / S4 : 1- 13B-re long block : 1 - 20b 3 rotor : 1 -KL MT : subaru engine : 1- ej20-t version-3 sti wiring ecu transmission differential setup : 3 - ej25de : Mitsubishi engine : 5 - 4g63-t MT Silver 95+ 1 - 6g72-tt MT wiring ecu : 1-4g63-t RED cyclone turbo honda engine : 3 - b16a hydro 92-95 mt trasmisison ecu : 3 -b16b engine Mt Axel SL Mounts Ecu : 2 -b16a engine 88-91 mt transmision ecu : 4- f20b mt lsd engine trans ecu : 2 - zc dohc EFI MT trans : 5 -b18b engine only obd2 : 3 -acura legend c32a engine auto transmisson : 1- h22a type-s mt lsd transmission wiring ecu : 5- h22a auto trans wiring ecu : 4 - f23a engine vtec auto tranny : 4 - b20z low intake : 1- k20a-R Accord Euro lsd transmisison 6speed ecu : 1 -k20a-R Rsx Type-R 6SPEED WIRING ECU : 1 -K20a-R Rsx Type-R 6SPEED WIRING ECU * INTAKE MANIFOLD BROKEN SMALL HOLE * : 2- K20a-R Rsx Type-R 6SPEED WIRING ECU AXEL SHIFTER + BREMBO + FRONT END : 3 -B18C Type R Spec-R 1998+ MOTOR TRANS LSD ECU AXEL SHIFTER : 1- f20c engine 6speed transsion wiring ecu : 4 -h23a dohc vtec auto trans wiring ecu : parts : 8 -5 lug integra / civic type-r brake conversion front and back : 5 - ctr 5 lug wheels with tire : 4 - ITR 5lug wheels with tire : 3 - type-r front clip black housing : 2 - ctr front end : 3 - recaro red seats ITR : 10- strut bar type-R 75$ 10- itr cluster : |
#35 |
I'm looking for some s13 redtop sr20det parts : 1 coil pack
Throttle body Fuel rail with injectors Flywheel Short shifter with trans plate And both engine and transmission harness. Would you be able to give me a good deal. My area code is 78002 in texas. Thanks Sent from my SGH-T999 using Tapatalk |
