![]() Join Date: Sep 2008
Uras seahorses, anyone used/using them?
I picked up a set, because I don't want to use a hydro.
Has anyone used them, if so was it worth it?
-Mike |
![]() Join Date: Apr 2008
I use them cant tell a difference. i run project mu d1 rear pads and they work amazing absolutely no need for the see horses. Pm me if you have more?? Bout this setup.
![]() Join Date: Nov 2008
I dont know what pad your running but I would try something better first. rears like to fade quick sometimes. You might try slotted and/or dimpled or drilled rotors to get rid of some heat too.
I see how the seahorses work, but if your having trouble right now without them, by the time you need to pull the brake a 2nd or 3rd time is it just going to be hard again due to fade? |
