Old 07-03-2015, 06:53 AM   #1
LowNSlowG
LowNSlowG is an unknown quantity at this point
Idel issue after fresh sr20det install
z32 MAF
255 fuel pump
550cc inj
entahlpy tune
BOV is recirculated
If you run the car in boost then let off the throttle and put in the clutch it will dye out unless you feather the gas.
I had it even cut off on me not in boost, just coming to a stop and depressing the clutch and it will stall out.
Anyone have any ideas? IACV? I dont think its the BOV because it will do it out of boost.
Any help is appreciated because this is getting annoying.
LowNSlowG is offline   Reply With Quote
Old 07-03-2015, 09:12 AM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Sounds like a vacuum leak.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 07-03-2015, 09:47 AM   #3
LowNSlowG
Would the vacuum leak cause it to stall all the time? It runs fine most of the time and if you switching gears nothing happens. The moment you hit the clutch and the RPM fall it kills. It will randomly do it as well under normal driving.
Old 07-03-2015, 10:16 AM   #4
Kingtal0n
Kingtal0n's Avatar
#/f/showthread.php?t=606635
Old 07-03-2015, 10:36 AM   #5
LowNSlowG
Originally Posted by Kingtal0n View Post
Trust me I have already used the search button and that thread (which I read) is not the same issue. Vehicle down not bog down when hitting the throttle. I can keep the car running after boost if i feather the gas. If I do not then it will die out on me. Again this has happened even out of boost and just normal driving (when coming to a stop and clutch is in).
Old 07-03-2015, 12:25 PM   #6
Kingtal0n
Kingtal0n's Avatar
99,847 people have come with this exact same problem and its been fixed the same exact way, and you think you have the only 1 engine that doesn't have an idle speed affected by air and fuel?
heres a spoon
compression test
boost leak test
bypass test
raise idle speed with screwdriver if its too low
Old 07-03-2015, 12:31 PM   #7
LowNSlowG
heres a spoon
compression test
boost leak test
bypass test
I don't think in one post I was ever disrespectful to you so I don't need you addressing me in that way either. I asked a simple question to see if someone could help me. If you don't like what I post then just don't reply.
Have a good one.
Old 07-03-2015, 02:27 PM   #8
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Cap off the bov and see if the problem persists. It's not the way you asked, it's the fact that you haven't bothered to do the research. The issue you are describing is not a new phenomenon.
If you have tried all said fixes and then come looking for help you may be received a little better.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 07-03-2015, 02:31 PM   #9
LowNSlowG
I have clamped the vacuum line going to the BOV and problem still exist.
Old 07-03-2015, 03:35 PM   #10
Kingtal0n
Kingtal0n's Avatar
thats not what he said to do. Cap the bypass (PLUG IT WITH A SOCK AND TAPE) not the vacuum line to the bypass.
https://tinyurl.com/turbo240
