Alpha-N tuning
Hello friends,
Can anyone point me to some good resources on doing an Alpha-N tune for an ITB setup? Is anyone on here running such a tune? What sort of management can be used? I will most likely be using Nismotronic, which seems like the best deal so far. Thank you for any information. |
#4 | |
NismoTronic SA has the capability to run alpha N or a hybrid alpha N and speed density for fueling and ignition scales. You can achieve this by setting the SET1 maps to Speed Density (map sensor) and setting the SET2 maps to alpha N (TPS only), then you can switch to the SET 2 maps in the software when you are over a certain MAP load value. This requires a decent vacuum block and vacuum source from each runner and the map sensor is usually mounted right to the vacuum block to help dial in idle and part throttle drivability.
![]() NismoTronicSA Tuning Package Dyno Tuning and ECU Services Mustang AWD-150 | DynaPack 3000 |
