![]() Join Date: Apr 2010
240sx S14 SR20det Wiring harness swap
Any1 have a link or a write up on what needs to be done for a s14 SR20DET wire swap in a 240sx s14? seem just find alot of s13 wire swaps, but s14 harnesses r different. help is appreciated.
o ya or maybe a S14 SR20DET manual in english? thanks! ![]() |
im doing this same swap, s14 sr into my 97 240, and ive been searching online for 4 months, and i have found a few things, but there is no 100% complete write up on this. but with wiring from what Ive read so far from alot of different sites is there are only 3 plugs that need to be rewired/repined, the wiper motor and the wiper amp plug needs to either have the wires crossed or match it up with the one on the KA harness or splice the KA plug on to the SR harness in those 2 spots. the other plug is the dash connecter behind the ecu. basically you have to repin/rewire the plug on the sr harness to match the plug on the 240. that is were all the confusion is. only sure way is to have the correct pinouts for your specific 240 and the pinouts for the specific sr you have.
#/f/tech-talk/209158...4-chassis.html
thats a thread on this site i found, its got some good info, and talks about what i posted earlier. |
Im finishing up this swap and theres basically nothing on it besides that thread. I still have like 4 harness plugs without a home not including the 3 that dont get used. Other than that im just waiting on my rad to get here and my swap is complete.
http://www.freshalloy.com/forums/sho...d.php?t=157283
also a good thread search the OP of the link i posted in almost any nissan site and you can find good info lol |
http://forums.nicoclub.com/preparing...d-t486211.html
my thread on nico this is where im at currently in my swap |
Preparing for my first sr swap and build : 240SX Technical Forum
![]() Join Date: Jan 2005
One of the problems with doing write-ups on wiring is that unfortunately someone will pop into your thread and tell you "Your doing it wrong!" or "Your gonna fry your ECU!" My friend has done a few swaps and a write-up on the S14 sr into an S13. I can tell you his car runs perfect...yet still someone will jump into his thread and say "It will never work!"
If you are still having issues pm me and I will see if he can help you out. |
https://spreadsheets.google.com/ccc?...1dWdVTGc&hl=en
known working repin diagram the ka pinout is a 95 240sx and sr pinout is a zenki s14 sr20, middle diagram is the modified to work version. this is the FIRST diagram i have found that is not backwards. |
