So I bought a used ISR Oilpan for an SR20det..
So I bought a used ISR Oilpan for an SR20det and it seems to be in fairly good condition. Only problem is it didnt come with the necessary hardware.
Also, the drain bolt is tiny as shit, and I am pretty sure every bolt on this pan uses an allen key. I cant fit a 10 mm socket inside the 4 holes that use longer bolts so id imagine its something else holding them down. I am awaiting a response from ISR Performance but I am just looking for anyone that has come across this issue and would like to help me out with specs so i dont purchase too short of bolts or even the wrong type. This a couple of the last pieces of putting my SR back together after rod knock and i would hate to do it incorrectly. Thank you so much for your help and I am looking forward to your responses. |
The hardware is M6x1.00
My pan was missing hardware so I had to purchase some, I used M6x1.00 30mm (has to be allen head bolts) for the 4 longer bolts and the rest are M6x1.00 20mm Also as for the drain plug it's the standard Nissan/Toyota thread pitch M12x1.25 ISR and P2M both make magnetic plugs for this thread pitch which would convert it to a hex style bolt. |
It's a metric thread pitch M12x1.25, not an NPT thread.
| 240sx, isis, oilpan, s13, sr20det |
