Front Crossmember Removal
Hey,
Okay, I searched for alot of different variations of "Crossmember" (Crossmember, Front Crossmember, Crossmember removal). I found 3 threads and they were not that helpful for the problem I am having. Okay, I am doing the front crossmember replacement on my S13. I have an engine hoist that is supporting the motor, and a full socket/ratchet/toolset. No air tools though. I also got a 10'' 1/2'' drive socket extension. This extension was what I was using until I came up with a horrible problem. As some of you know, the crossmember is the big suspension piece that you jack your car up with, it supports the engine mounts. I have to take mine off. Well, on the exact part of the crossmember (underneath the crossmember) where you see a thread sticking out with a stupid nut on it (it's on the part of the crossmember that has the engine mount on it), I tried to take that bolt off. It's soo hard getting leverage on that one nut, and it's even harder for the left side engine mount nut, I tried my best to hold it straight and loosen it. It didn't work, and the nut got kind of stripped. Can anybody go more in-depth (than the other threads) as to how you get that damn bolt off? I'm thinking of buying another new thread/nut from the dealership ($6) and drilling/chizelling this shit off. Can anybody describe what exactly they had to do when swapping their crossmember? I'm having too much trouble :*(
White '90 S13 Fastback (SOLD in '07) |
